Gimp 2 doesn't see my xsane scanner anymore!
3 of 4 messages available
Gimp 2 doesn't see my xsane scanner anymore! Laurence Orchard 30 Jun 22:56
  Gimp 2 doesn't see my xsane scanner anymore! Jean-Luc Coulon (f5ibh) 30 Jun 23:11
1088684841.11456.30.camel@l... 07 Oct 20:16
  Gimp 2 doesn't see my xsane scanner anymore! Jean-Luc Coulon (f5ibh) 01 Jul 14:45
Laurence Orchard
2004-06-30 22:56:44 UTC (over 21 years ago)
Hi
I have installed Gimp 2 onto my FC1 system along side a 1.2 & 1.3. The I have a USB HP OfficeJet 6110 that has a built in scanner. This scanner is found and recognised by version 1.2, but not by version 1.3 or Gimp 2.
Question: How do I get Gimp 2 to see it?
Laurence
2004-06-30 23:11:06 UTC (over 21 years ago)
On Wed, Jun 30, 2004 at 09:56:44PM +0100, Laurence Orchard wrote:
Hi
You have to use the latest version of xsane. 0.94 is the latest one.
- Jean-Luc
Laurence
2004-07-01 14:45:38 UTC (over 21 years ago)
Le 01.07.2004 14:27:21, Laurence Orchard a écrit :
Hi
1.3.
This
version
1.3
or Gimp 2.
OK ! i have downloaded, compiled & installed 0.94. It will run stand alone, but not as a plugin.
xsane-gimp doesn't exist anymore, not even in /usr/local/bin the ? new?
default dir.
If you have xsane installed in /usr prefix you shoud have a /usr/bin/ xsane executable for it ("which xsane" will tell you where it is located).
Go to your .gimp-2.0/plug-ins directory (in your home directory) and add a symlink to the xsane binary :
cd .gnome(2.0/plug-ins
ln s /usr/bin/xsane
This will give the following symlink: xsane -> /usr/bin/xsane
For a general usage on your machine you can make the symlink in /usr/lib/gimp/2.0/plug-ins
--- Regards
- Jean-Luc
- Jean-Luc
Laurence
