Stuck Gimp
Stuck Gimp Jonathan Allen 18 Oct 11:07
  Stuck Gimp Shlomi Fish 18 Oct 12:42
  Stuck Gimp Liam R E Quin 19 Oct 04:39
Jonathan Allen
2012-10-18 11:07:57 UTC (over 12 years ago)
Stuck Gimp
Help!
I've got my Gimp stuck. Something happened and it gets stuck in the file dialogue. It will open recently used files, but goes into a brown study on File->Open or File->Save-As and the only way out is force-quit. This Gimp 2.2 on an older Fedora box. Any clues how to get it going again?
Jonathan
Shlomi Fish
2012-10-18 12:42:38 UTC (over 12 years ago)
Stuck Gimp
Hi Jonathan,
On Thu, 18 Oct 2012 12:07:57 +0100 Jonathan Allen wrote:
Help!
GIMP 2.2 is ancient history. GIMP 2.4.x, GIMP 2.6.x and GIMP 2.8.x were released since then (and the GIMP project was criticised for having a long release schedule). I don't think it's still supported and I would imagine your Fedora version to be very old too.
You really should upgrade, because you are risking much graver problems than GIMP getting stuck in the file dialogue (among them getting a huge security risk exploited and your system compromised). See:
http://szabgab.com/what-does--if-it-aint-broke-dont-fix-it--really-mean.html
Otherwise, if you're not going to upgrade, then I personally refuse to help you any further from the reasons that for all I know it could be a problem in your old and unsupported set up. See:
* http://www.shlomifish.org/humour/fortunes/show.cgi?id=hamakor-discs-mozilla-1.1-1
* http://www.shlomifish.org/humour/fortunes/show.cgi?id=hamakor-discs-commodore-64--1
Shlomi Fish
Liam R E Quin
2012-10-19 04:39:38 UTC (over 12 years ago)
Stuck Gimp
If you can upgrade, do so. Buy more memory if necessary.
If not... see if you can open other files with other gnome programs such as gedit. Most likely causes -
. your hard drive is failing
. there's a network file system mount that isn't responding . gimp has arthritis. Massage some celadrin, glucosamin sulphate and some IP6 onto the soles of its feet. :-) . run gimp under strace or under gdb and see what it's waiting for. This generally requires some technical systems knowledge to interpret the output.
. be *much* more specific about "it goes into a brown study". Is the study carpeted? Are there leather-bound books? Does the file chooser window appear or not? If it appears what does it look like? Are we to read your mind? Does it make a difference what colour socks you are wearing? Was your system previously on a network? Are any file systems full or nearly full? Are you running any other programs or services?
It's pretty hard to support software this old (it was released in 2004), and you must be prepared to give a LOT of information.
Liam
