interface to ufraw -- save options
10 of 10 messages available
interface to ufraw -- save options Gary Aitken 21 Sep 04:37
  interface to ufraw -- save options Liam R E Quin 21 Sep 04:54
   interface to ufraw -- save options Gary Aitken 21 Sep 22:02
    interface to ufraw -- save options Gerald 21 Sep 22:17
     interface to ufraw -- save options Ofnuts 21 Sep 22:32
      interface to ufraw -- save options Partha Bagchi 21 Sep 22:35
    interface to ufraw -- save options Alexandre Prokoudine 21 Sep 22:48
     interface to ufraw -- save options Gary Aitken 22 Sep 05:01
    interface to ufraw -- save options Liam R E Quin 22 Sep 00:03
    interface to ufraw -- save options Patrick Shanahan 22 Sep 00:51
Gary Aitken
2012-09-21 04:37:16 UTC (over 12 years ago)
Hi all,
I've got a script for processing a bunch of files which starts by bringing up ufraw. I would like to have ufraw save the list of modifications made before returning to gimp. (.ufraw file)
However, when gimp starts ufraw, it passes some option to ufraw which causes ufraw to not display the save tab which allows setting what to save.
Is there a way to tell gimp to bring up ufraw differently, or is the problem in ufraw?
Thanks for any insights,
Gary
Liam R E Quin
2012-09-21 04:54:14 UTC (over 12 years ago)
You can run ufraw outside of gimp, not as a plugin.
There are also other raw camera image processing tools, including for example darktable, although that has a really confusing user interface and I always end up using google to search for how to save files! But it's still useful if you don't mind its weirdness.
Liam
Gary Aitken
2012-09-21 22:02:23 UTC (over 12 years ago)
I'm trying to automate a process, and don't want to have to manually start ufraw. I could start ufraw and use its "gimp" button to transfer control to gimp, but that doesn't do what I want either -- if you tell ufraw to "save" to get the .ufraw file saved, it quits; so then you can't transfer control to gimp.
Fundamentally, I want to do the following:
specify a set of raw file names to process specify a destination directory
for each raw file:
a. process in ufraw a1. manual crop, etc., if desired a2. save a .ufraw file in the source directory b. process in gimp
b1. manual manipulation if desired b2. automatic resizing and sharpening, etc b3. automatically generate a .jpeg file in the destination directory
With the exception of the input file names and the output directory, (and a1 and b1)
I want everything else done automatically.
I tried using a shell script and having ufraw write a .tif intermediary; however, that has the following problem:
In step b3, I need to get the destination directory name, and I can't figure out how to do that automatically.
A command line arg like "-DDEST_DIR foo" would be great, but I don't see anything in the man page for defining an arbitrary input arg which a script could have access to. An arg in a script can have a fixed default value, but that's not what I need.
One could get really gross and dynamically generate a script with the proper default for the arg before starting gimp, but that's sick :-).
I'm all ears for any suggestions.
Gary
Gerald
2012-09-21 22:17:19 UTC (over 12 years ago)
I'm all ears for any solutions !!!
Le 2012-09-21 18:02, Gary Aitken a crit :
La Photo Du Jour
http://gb-photodujour.com
Sur internet depuis juin 1998
gimp-user-list mailing list
gimp-user-list@gnome.org
2012-09-21 22:32:52 UTC (over 12 years ago)
As far as I know, UFRaw is mostly a graphical front-end for the command-line utility DCRaw.
Partha Bagchi
2012-09-21 22:35:41 UTC (over 12 years ago)
It is a modified version and so not as up to date as DCRaw which has all the options you need. :)
2012-09-21 22:48:01 UTC (over 12 years ago)
for each raw file:
Is there a reason you can't save .ufraw for each file, then run ufraw in batch mode to create TIFF files for further editing with GIMP?
I'm wondering, because it's something I used to do a lot some 4 or 5 years ago, before darktable was conceived.
Liam R E Quin
2012-09-22 00:03:39 UTC (over 12 years ago)
for each raw file:
Sounds to me like you could do this in darktable just as easily.
b. process in gimp
You could use one of the gimp batch processors to do b2 and b3 if you save as xcf or xcf.gz at the end of b2.
Or just copy all the files from one to the other, which is a single command.
Liam
Patrick Shanahan
2012-09-22 00:51:20 UTC (over 12 years ago)
* Gary Aitken [09-21-12 18:05]:
have you looked at "ufraw-batch" ??
Gary Aitken
2012-09-22 05:01:32 UTC (over 12 years ago)
for each raw file:
Thanks for the suggestion; a variant of that idea may work.
On 09/22/2012 12:17 AM, Gerald wrote: As far as I know, UFRaw is mostly a graphical front-end for the command-line utility DCRaw.
Unfortunately, I need the gui interface to determine what the parameters should be -- crops and exposure mods, for example.
