remove dust problems
7 of 7 messages available
remove dust problems David Holland 20 Sep 19:51
  remove dust problems scl 20 Sep 20:47
   remove dust problems elmer 44m 21 Sep 05:17
    remove dust problems scl 22 Sep 05:19
  remove dust problems Nik Omul 21 Sep 04:59
   remove dust problems David Holland 21 Sep 19:56
    remove dust problems David Holland 06 Apr 15:50
David Holland
2012-09-20 19:51:42 UTC (over 12 years ago)
Hi All,
I tried to remove a dust spot using resynthesize but I can still see where it was, although it looks a lot better.I was using this tutorial. http://dodonov.net/blog/2009/12/29/cleaning-dust-on-photos-or-in-gimp-we-trust/ Any ideas?Here is the original
http://www.flickr.com/photos/14586608@N08/8007061865/in/photostreamthe modifiedhttp://www.flickr.com/photos/14586608@N08/8007047321/in/photostream
Thanks a lot in advance
scl
2012-09-20 20:47:09 UTC (over 12 years ago)
On 20.09.12 at 9:51 pm David Holland wrote:
I tried to remove a dust spot using resynthesize but I can still see where it was, although it looks a lot better. I was using this tutorial.
Hi David,
this is easy:
1. Create a new transparent layer above the image layer and activate it. 2. Use the Clone tool, enable 'Sample merged' and use a soft brush for cloning.
3. Select the source region. It should have the same or a very similar color and structure as the destination region. 4. Clone the dust spot away. Use the Healing tool and layer opacity to refine your work.
5. To make the outline softer, you can blur it with the Gaussian blur filter. To undo some cloned parts and uncover the original image use the Eraser tool on the upper layer.
This is based upon a tutorial in Michael Fryes book 'Digital landscape photography'.
Kind regards,
Nik Omul
2012-09-21 04:59:14 UTC (over 12 years ago)
David Holland wrote
Hi All,
gimp-user-list@
Hi, David.
Assuming you have Resynthesizer + Heal Selection plugin installed (if not, find it in Plugin Registry),
use the latter (Filters>Enhance>Heal Selection). You can see the difference here
http://i1249.photobucket.com/albums/hh513/nikomul1/testingHealSelection_zps3b856d5f.jpg
Heal Selection beats Resynthesize, Clone Tool and Healing Tool at removing even much
bigger than dust particles objects (for demonstration purposes I removed two birds (pelicans?) as well ^)
Cheers,
Nik O.
Никита Омуль
View this message in context: http://gimp.1065349.n5.nabble.com/remove-dust-problems-tp35707p35720.html Sent from the Users mailing list archive at Nabble.com.
elmer 44m
2012-09-21 05:17:08 UTC (over 12 years ago)
Hi David,
All this is too complicated. Just use the Healing Tool.
Elmer
Hi David,
this is easy:
Kind regards,
Sven _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
David Holland
2012-09-21 19:56:58 UTC (over 12 years ago)
That looks amazing thanks a lot, I will try and let you know how I get on.(I am flying tonight so it might not be for some time).
--- On Fri, 21/9/12, Nik Omul wrote:
From: Nik Omul Subject: Re: [Gimp-user] remove dust problems To: gimp-user-list@gnome.org
Date: Friday, 21 September, 2012, 5:59
David Holland wrote
Hi All,
gimp-user-list@
Hi, David.
Cheers,
Nik O.
Никита Омуль
scl
2012-09-22 05:19:25 UTC (over 12 years ago)
this is easy:
Hi Elmer,
your right in the point that the Healing tool has just one step while the other way as five. It's a very easy and smart way, but doesn't offer a possibility to edit or revert the changes later at any arbitrary time. Many roads lead to Rome and I described the nondestructive one. It has the benefit of being able to edit or revert the work later (see steps 4 and 5), even after having gone a few steps further in the meantime. As you stated correctly, it has more steps and thus looks more complicated. So, David now knows three methods (the Healing tool, the nondestructive way and content-aware fill) and it's up to him to prefer one or to decide for each scenario.
Hopefully GIMP will combine the power of nondestructive editing with the ease of using just a single tool one day. With respect to the roadmap it's yet a future milestone, but the first steps are currently being gone with the GEGL port.
Kind regards,
David Holland
2013-04-06 15:50:47 UTC (about 12 years ago)
Thank you so much for your help.  I had some serious problems with my PC and my health so have only just got a chance to do this, it worked really well on the 1 photo I have tried so far http://www.flickr.com/photos/14586608@N08/8625118958/in/photostream
http://www.flickr.com/photos/14586608@N08/8625118866/in/photostream
--- On Fri, 21/9/12, David Holland wrote:
From: David Holland Subject: Re: [Gimp-user] remove dust problems To: gimp-user-list@gnome.org, "Nik Omul" Date: Friday, 21 September, 2012, 20:56
David Holland wrote
Hi All,
gimp-user-list@
Hi, David.
use the
Cheers,
Nik O.
Никита Омуль
-----Inline Attachment Follows-----
