procedure overloading in scheme / script-fu
procedure overloading in scheme / script-fu Gary Aitken 18 Sep 22:42
  procedure overloading in scheme / script-fu paynekj 19 Sep 13:39
  procedure overloading in scheme / script-fu Kevin Cozens 19 Sep 14:53
Gary Aitken
2012-09-18 22:42:13 UTC (about 13 years ago)
I assumed from the scheme manual that procedure-overloading (in the form of different numbers of arguments) was permitted, since, for example, there are two versions of string->number. However, I can't seem to get it to work. Anything special one needs to do to overload?
If you take the following code and run it in the script-fu console, it works; but replacing all occurrances of "foo2" with "foo" gets into an infinite loop (I guess; it never returns, in any case). Is this just a user-error mistake,
or is there something different needed to overload a procedure definition? I realize the two arg definition had to appear before the one arg definition which used it; if the order is wrong I get the wrong # args error, which makes sense.
(define (foo2 arg1 arg2) (string-append arg1 arg2))
(define (foo arg1) (foo2 arg1 "def")) (foo "abc")
foo2foo"abcdef"
Thanks,
Gary
2012-09-19 13:39:03 UTC (about 13 years ago)
Can you point me to the scheme manual that talks about overloading please.
As you are talking about variable numbers of arguments, this article seems to explain how it works: http://www.math.grin.edu/~stone/courses/scheme/readings/variable-arity.xhtml
And in your example, by replacing foo2 with foo you end up with a second definition of foo which replaces the first, and then calls itself recursively when used - hence your infinite loop.
Kevin Cozens
2012-09-19 14:53:11 UTC (about 13 years ago)
Scheme is not an OOP language so it does not support procedure overloading. If you look closely, you will see that string->number and number->string can take an optional parameter, a radix to use during the conversion. The optional radix parameter is not currently supported for either string->number or number->string.
Code to add support for the radix was supplied to the TinyScheme project and is currently being reviewed so radix support may be added soon to Script-Fu.
If you changed all foo2 to foo, then foo continually calls itself and the console will appear to hang.
