script-fu: illegal function?
script-fu: illegal function? Gary Aitken 17 Sep 18:28
  script-fu: illegal function? Kevin Cozens 17 Sep 22:47
   script-fu: illegal function? Richard Gitschlag 18 Sep 03:44
    script-fu: illegal function? Gary Aitken 18 Sep 22:07
     script-fu: illegal function? Kevin Cozens 18 Sep 22:17
Gary Aitken
2012-09-17 18:28:50 UTC (about 13 years ago)
When I try the following in the script-fu console:
((define (find-dot txt txtLen offset) (print "foo")) (find-dot "abcd.ef" 7 1)) "foo"
Error: illegal function
The find-dot macro obviously exists and is being executed. So what is the illegal function it is complaining about?
Thanks
Kevin Cozens
2012-09-17 22:47:38 UTC (about 13 years ago)
First, you wrapped the whole thing in ( ). Drop the leading and trailing parentheses.
Second, that is a line of Scheme code and Scheme does not contain a "print" function. You probably meant to use "display". Also keep in mind that the "display" function only takes a string so you may first need to convert what you pass it to a string.
Richard Gitschlag
2012-09-18 03:44:41 UTC (about 13 years ago)
That's right - parentheses are not "free" in Scheme scripting, every opening parenthesis must be immediately followed by a function call. When you just want parentheses to group a few statements together with, call the (begin ... ) function:
(begin (function a) (function b) (etc ) ... )
Date: Mon, 17 Sep 2012 18:47:38 -0400 From: kevin@ve3syb.ca
To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] script-fu: illegal function?
Cheers!
Kevin.
http://www.ve3syb.ca/ |"Nerds make the shiny things that distract Owner of Elecraft K2 #2172 | the mouth-breathers, and that's why we're | powerful!" #include | --Chris Hardwick _______________________________________________ gimp-user-list mailing list
Gary Aitken
2012-09-18 22:07:37 UTC (almost 13 years ago)
Thanks, both of you for clarifications. Not sure where I saw the "print" but it seems to work:
(define (find-dot txt txtLen offset) (print "foo") "xyz" "pqr") (find-dot "abcd.ef" 7 1)
find-dot"foo"
"pqr"
(define (find-dot txt txtLen offset) (display "foo") "xyz" "pqr") (find-dot "abcd.ef" 7 1)
find-dotfoo"pqr"
The function itself seems to be accepted. It appears the difference between using "display" and using "print" is that "print" outputs enclosing double quotes plus trailing newline; "display" outputs the unadorned string and no trailing newline.
-- Stratadrake
strata_ranger@hotmail.com
> Date: Mon, 17 Sep 2012 18:47:38 -0400 > From: kevin@ve3syb.ca
> Subject: Re: [Gimp-user] script-fu: illegal function? >
> On 12-09-17 02:28 PM, Gary Aitken wrote: > > ((define (find-dot txt txtLen offset) (print "foo")) (find-dot "abcd.ef" 7 1)) >
> First, you wrapped the whole thing in ( ). Drop the leading and trailing > parentheses.
> Second, that is a line of Scheme code and Scheme does not contain a "print" > function. You probably meant to use "display". Also keep in mind that the > "display" function only takes a string so you may first need to convert what > you pass it to a string.
> Cheers!
> Kevin.
> http://www.ve3syb.ca/ |"Nerds make the shiny things that distract > Owner of Elecraft K2 #2172 | the mouth-breathers, and that's why we're > | powerful!"
> _______________________________________________ > gimp-user-list mailing list
Kevin Cozens
2012-09-18 22:17:44 UTC (almost 13 years ago)
I just remembered that "print" is one of the deprecated functions that were part of the old SIOD days of Script-Fu. While "print" will work, it is not standard Scheme and should not be used in new scripts.
