Wacom Tablet not working with GIMP
| Wacom Tablet not working with GIMP | torreyproctor | 17 Sep 12:47 |
| Wacom Tablet not working with GIMP | Patrick Shanahan | 17 Sep 13:12 |
| Wacom Tablet not working with GIMP | Richard Gitschlag | 17 Sep 13:57 |
| Wacom Tablet not working with GIMP | Jehan Pagès | 17 Sep 16:46 |
| Wacom Tablet not working with GIMP | Marathon7 | 07 Dec 20:23 |
| Wacom Tablet not working with GIMP | Patrick Shanahan | 07 Dec 20:47 |
| Wacom Tablet not working with GIMP | Partha Bagchi | 07 Dec 20:58 |
| Wacom Tablet not working with GIMP | Marathon7 | 07 Dec 21:30 |
| Wacom Tablet not working with GIMP | Partha Bagchi | 07 Dec 21:53 |
| Wacom Tablet not working with GIMP | Marathon7 | 07 Dec 23:24 |
- postings
- 1
Is their a way to get the pressure sensitivity of my Wacom Bamboo Capture tablet working with GIMP. Is tablets pressure sensitivity still unavailable to GIMP 2.8.2 Mac OS X?
* torreyproctor [09-17-12 08:48]:
It works with mine on openSUSE 12.2+Tumbleweed. Just had to plug it in.
Don't know about mac
It is a known bug that GIMP completely fail to detect a tablet that does in fact exist during its startup process (and there is no way to make GIMP re-check its input devices besides closing GIMP and restarting). To check if this is the case with you, try running your pen across the tablet for a second or two before you actually start GIMP (or access your GIMP shortcut via tablet pen).
It may not be the problem, but if this step works then you have a pretty easy workaround at your disposal.
-- Stratadrake
strata_ranger@hotmail.com
Date: Mon, 17 Sep 2012 14:47:35 +0200 From: forums@gimpusers.com
To: gimp-user-list@gnome.org
CC: team@gimpusers.com
Subject: [Gimp-user] Wacom Tablet not working with GIMPIs their a way to get the pressure sensitivity of my Wacom Bamboo Capture tablet working with GIMP. Is tablets pressure sensitivity still unavailable to GIMP 2.8.2 Mac OS X?
-- torreyproctor (via gimpusers.com)
I have a Wacom Bamboo, and I have Gimp from the source repository. So I can confirm it works well in the last version. :-)
There are 2 tricks.
1/ As someone said, you may have to plug your tablet *before* starting Gimp.
But I doubt this is your issue. My bet is:
2/ Go in Edit > Input Devices.
You should see a list of devices showing up in the list for your tablet, ie:
Wacom Bamboo
Wacom Bamboo cursor/erasor/pad/stylus
Go into each one of them. By default, the mode will be "Disabled".
Change it to "Screen".
After you have changed all of them, "Save" and "Close".
Try again. You'll have pressure sensitivity. Enjoy.
Jehan
- postings
- 3
I tried really hard to get my Wacom Intous4 table connected with GIMP 2.8.10 under MAC OSX 10.9. However it is not recognized by GIMP - (all other programs I used can detect the driver correctly). Also I updated the Wacom driver to the newest version - without any effect.
What confuses me is that it some Forums it's mentioned that XQuartz is necessary to run GIMP and a tablet, in some comments it's confirmed that it's not needed anymore...
Also it's interesting, that some users can use their Wacom Intous3 tablet with GIMP 2.8.... which gives me hope that there is a trick...
Any hint ? Anyone?
Greetings from Finland ! Marathon7
* Marathon7 [12-07-13 15:26]:
Apparently a problem with the mac build or mac environment as I have no problem at all with my Bamboo tablet with gimp 2.8.[6,8,10] on openSUSE KDE Tumbleweed.
(paka)Patrick Shanahan Plainfield, Indiana, USA @ptilopteri http://en.opensuse.org openSUSE Community Member facebook/ptilopteri http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 Registered Linux User #207535 @ http://linuxcounter.net
Download McGimp 2.8.10 from my website, www.partha.com and let me know if you still have issues.
Thanks, Partha
under MAC OSX 10.9.
driver correctly).
Also I updated the Wacom driver to the newest version - without any effect.What confuses me is that it some Forums it's mentioned that XQuartz is necessary
in some comments it's confirmed that it's not needed anymore...Also it's interesting, that some users can use their Wacom Intous3 tablet with
GIMP 2.8.... which gives me hope that there is a trick...Any hint ? Anyone?
Marathon7 (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
List address: gimp-user-list@gnome.org List membership: https://mail.gnome.org/mailman/listinfo/gimp-user-list
- postings
- 3
you still have issues.Thanks, Partha
Hi Partha, many thanks for your quick answer - I do appreciate! I downloaded the 64 bit version of the Gimp 2.8.10 from your website, deinstalled my old Gimp and started the new version. No changes. Then I restarted my MAC again - no changes again. I always plug in the tablet before I start Gimp with my pen.
I just wonder what we can do to improve this... There is not much on the Wacom Forum as well...
Thanks again for your effort !
BR
Marathon7
Screenshot
Do you have the Mac drivers installed/loaded btw?
I just tried it and did not have any issues with pressure sensitivity or starting a new painting etc.
Does your mouse pointer not move at all when you move the pen?
start Gimp with my pen.I just wonder what we can do to improve this... There is not much on the Wacom
Forum as well...Thanks again for your effort !
BR
Marathon7
Attachments: *
http://www.gimpusers.com/system/attachments/84/original/Bildschirmfoto_2013-12-07_um_23.20.24.png-- Marathon7 (via www.gimpusers.com/forums) _______________________________________________ gimp-user-list mailing list
- postings
- 3
Hi again,
Yes, I installed MacOSX - Driver 6.3.7-3 (10.6x - 10.9x)
starting a new painting etc.Does your mouse pointer not move at all when you move the pen?
The pointer or pen do work in such a way that I can draw lines. Also the eraser works, as well as one pen button. However all other functions of the tablet are not supported - because not detected. Like the touch ring, e.g. to manipulate the brush size, or turn the picture, zoom in etc.
Only rudimentary functions are working.
BR
Marathon7
