Help needed making a gradient in Gimp 2.0.1
Help needed making a gradient in Gimp 2.0.1 Tom Williams 20 Jun 05:07
  Help needed making a gradient in Gimp 2.0.1 matt-nc 20 Jun 05:24
   Help needed making a gradient in Gimp 2.0.1 Tom Williams 20 Jun 05:31
   Help needed making a gradient in Gimp 2.0.1 Owen Cook 20 Jun 06:01
    Help needed making a gradient in Gimp 2.0.1 Tom Williams 20 Jun 06:42
  Help needed making a gradient in Gimp 2.0.1 Greg Rundlett 23 Jun 04:14
Tom Williams
2004-06-20 05:07:37 UTC (almost 21 years ago)
Ok, I'm trying to make a gradient that looks exactly like this:
http://www.bay-online-media.com/tom/graident.jpg
I'm starting with a duplicate of the "FG to BG (RGB)" gradient and I can edit my copy just fine. However, I just can't get the threshold just right such that the color change looks just like in the image above.
If anyone can get it figured out, I would be very appreciative! :)
Thanks in advance!
Peace...
Tom
matt-nc
2004-06-20 05:24:41 UTC (almost 21 years ago)
FYI (spelling correction for the link)
http://www.bay-online-media.com/tom/gradient.jpg
Tom Williams
2004-06-20 05:31:17 UTC (almost 21 years ago)
Doh! Sorry about that! Thanks for the correction. :)
Peace...
Tom
Owen Cook
2004-06-20 06:01:22 UTC (almost 21 years ago)
You don't want to copy it?
According to my Gimp, it is a 20x684 @ 72dpi RGB image with a start color of 40508c and an end color of 5470af(see color picker)
So, create a new image 20x684 @ 72dpi, set the foreground color to 40508c and a background color of 5470af. Then use the "Fill with Gradient tool" and fill from top to bottom.
Or did you want to do something else?
Owen
Tom Williams
2004-06-20 06:42:10 UTC (almost 21 years ago)
Owen
Thanks! That worked out great!
Peace...
Tom
Greg Rundlett
2004-06-23 04:14:50 UTC (almost 21 years ago)
Not sure if you realized this or not, but maybe it will help.
Given a selected area, if you start the gradient tool "early" (before the selection or layer), it will have already begun to fade by the time you enter the selection/layer area. Likewise, if you start at the precise border, but you extend your 'stroke' of the gradient tool well past the frame of the selection or layer area, you will have an ending color that is closer to the foreground color than it is to the background color.
This in no way controls specificly at what interval and rate the gradient changes, but I thought it might be helpful to point out that the gradient doesn't have to start and end on the foreground and background colors.
- Greg
