Gimp perl doesn't work
Gimp perl doesn't work v.demartino2@virgilio.it 18 Jun 14:07
  Gimp perl doesn't work Sven Neumann 18 Jun 14:49
   Gimp perl doesn't work v.demartino2@virgilio.it 18 Jun 18:32
2004-06-18 14:07:54 UTC (about 21 years ago)
Under linux debian testing I've installed all gimp 2 deb packages for sarge including gimp-perl-2.0. The latter doesn't seem to work because at the end of the installation I cannot find any of the Gimp.pm, Fu.pm, etc module files needed to run a perl scritpt.
From CPAN I downloaded the Gimp-2 tar.gz stuff and when I issue "perl Makefile.PL"
the result is:
checking for gimptool-2.0... /usr/bin/gimptool-2.0 checking for GIMP - version >= 2.0.0... no *** Could not run GIMP test program, checking why... *** The test program failed to compile or link. See the file config.log for the
*** exact error that occured. This usually means GIMP was incorrectly installed *** or that you have moved GIMP since it was installed. In the latter case, you
*** may want to edit the gimptool-2.0 script: /usr/bin/gimptool-2.0 configure: error: ** unable to find gimp, make sure it's in your path (version 1.3.15+ required!)
And in config.log: -------------------
configure:2521: error: ** unable to find gimp, make sure it's in your path (version 1.3.15+ required!)
which apparently isn't true because I currently use Gimp 2
What's going on and what should I do?
Vittorio
2004-06-18 14:49:23 UTC (about 21 years ago)
v.demartino2@virgilio.it writes:
The gimp package (which is gimp-2.0.2 at the moment) isn't in debian testing yet. What did you install?
2004-06-18 18:32:12 UTC (about 21 years ago)
You're right not in the official Debian site but as contributed deb packages in
http://mars.iti.pk.edu.pl/~jakub/
found in www.gimp.org
Ciao Vittorio
-- Messaggio originale --
To: v.demartino2@virgilio.it
Cc: "gimp-user"
Subject: Re: [Gimp-user] Gimp perl doesn't work From: Sven Neumann
Date: 18 Jun 2004 14:49:23 +0200
