Text with multicoloue horizontal stripes
Text with multicoloue horizontal stripes RichardAinz 25 Jul 17:06
  Text with multicoloue horizontal stripes Ofnuts 25 Jul 17:56
2012-07-25 17:06:56 UTC (over 13 years ago)
Hi. I am new. Both here and to Gimp. Tested it a bit on and off, but the breakthrough for me was the single window mode, so now I am currently making an effort to learn something.
My first question is actually about somethin I am failing to do with Photoshop CS4. I create a text, rasterize it, then create the stripes via the rectangle tool (in this case I am messing with different national colours, like Germany). Now so far so god, but I never get around to actually be able to merge the strips with the text. The closest I have gotten is to see the text behind the stripes, but then the strips also covers the space between the text. I followed this tutorial for that: http://www.flash-game-design.com/tutorials/greenStripedText-photoshop-tutorial.html
I looked at Your Sweet Candy tutorial and, excluding some steps, seems to be relevant, but for step 15, where I do not want to select stripes available inGimp, but create new ones. Can you please point me in the right direction?
Thanks
2012-07-25 17:56:56 UTC (over 13 years ago)
- Create layer with text
- Create layer with stripes, covering at least the whole text - Select layer with text
- "Layer/Transparency/ Alpha to selection (you now have a selection that matches the shape of the text)
- Select layer with stripes
- Select/Invert (we want a selection on everything outside the text) - Select/Clear (or [Delete]): you have remove everything but the shape of the text
- Get rid of (or hide) the text layer
You can also generate the stripes using a gradient, in which case: - Create layer with text
- Add new layer
- Apply gradient (it will be restricted to the selection)
Or also: - Create layer with text
- Lock the alpha for the layer (check box at top of Layers list) - Apply gradient (won't apply on transparent parts due to alpha-lock)
