Problem running script-fu in bash script
Problem running script-fu in bash script Mathieu Masse 09 Jun 04:16
  Problem running script-fu in bash script Sven Neumann 09 Jun 12:58
   Problem running script-fu in bash script Simon Budig 09 Jun 13:42
   Problem running script-fu in bash script Mathieu Masse 09 Jun 13:57
Mathieu Masse
2004-06-09 04:16:04 UTC (about 21 years ago)
Hi list,
This is my first posting to the list, I've run into a small problem while writing a script to simplify some task. My script does the following: opens up a .jpg file, crops it, adds text to it, flattens the layers, and saves everything back. All this runs fine in Gimp (ie. from the Xtra menu and script-fu)
Now when I call this from a bash script it is also fine, my problem is that instead of passing fixed parameters to my script-fu script I want to pass bash variables, but I can't get this to work, I looked on the web and tried what people suggest but can't get it to work, please help.
Here is some info on everything: Red Hat 9.0
Gimp-1.2.3-16 (from Red Hat's rpm)
Here is my bash script:
***************** #!/bin/sh
fullpath=/home/mathieu/miscellaneous/backgrounds/weather_maps/temp.jpg current_time="13:25"
gimp -d -i --verbose -b '(script-fu-add-text-weather-map '$fullpath' '$file' '$current_time')'
Has you can see my gimp script as 3 parameters, which I want to pass as variables (fullpath, file, current_time).
TIA for the help
Mathieu
-- Mathieu Massé
Email: mathieu_masse@sympatico.ca
GPG Public Key available at http://www.keyserver.net Key fingerprint = 9C3F 7217 1AF5 0BC6 B502 79B3 B1BB 7360 D043 B69C
2004-06-09 12:58:02 UTC (about 21 years ago)
Mathieu Masse writes:
I'd say your quoting is wrong. You can hardly expect nested single ticks to work.
Try this instead:
gimp -d -i --verbose -b '(script-fu-add-text-weather-map "$fullpath" "$file" "$current_time")'
Simon Budig
2004-06-09 13:42:12 UTC (about 21 years ago)
Try this instead:
Single ticks in this case prevent the variables to be expanded.
Try this instead:
gimp -d -i --verbose -b "(script-fu-add-text-weather-map \"$fullpath\" \"$file\" \"$current_time\")"
Bye, Simon
Mathieu Masse
2004-06-09 13:57:34 UTC (about 21 years ago)
Try this instead:
That also does not work using the double quotes gimp thinks these are strings and does not evaluate the values of the variables...
Mathieu Massé
