Device specific tool options
Device specific tool options Mikael Ståldal 13 Jul 13:55
  Device specific tool options Alexandre Prokoudine 13 Jul 14:04
   Device specific tool options Richard Gitschlag 22 Jul 17:04
    Device specific tool options Mikael Ståldal 26 Jul 19:46
  Device specific tool options Liam R E Quin 14 Jul 02:48
   Device specific tool options Mikael Ståldal 22 Jul 11:08
Mikael Ståldal
2012-07-13 13:55:23 UTC (over 13 years ago)
It seems like GIMP save different tool options for different devices (such as mouse and drawing tablet). Is it possible to configure GIMP 2.8 to not do that, to share the same tool options among all devices?
2012-07-13 14:04:31 UTC (over 13 years ago)
Nope.
http://libregraphicsworld.org
gimp-user-list mailing list
gimp-user-list@gnome.org
Liam R E Quin
2012-07-14 02:48:47 UTC (over 13 years ago)
If you use the tablet as a regular mouse (no pressure...) then yes, but I think otherwise not right now.
Mikael Ståldal
2012-07-22 11:08:31 UTC (about 13 years ago)
I want to use the pressure of my tablet, no much point in having a tablet otherwise.
Then I would like to put an option to share tool options among all devices on the wishlist for some future version of GIMP.
Richard Gitschlag
2012-07-22 17:04:58 UTC (about 13 years ago)
Date: Fri, 13 Jul 2012 18:04:31 +0400 From: alexandre.prokoudine@gmail.com To: gimp-user-list@gnome.org
Subject: Re: [Gimp-user] Device specific tool options
Nope.
To be more specific about this, certain options are saved with each tool, certain options are shared between all tools, and certain options are saved with each input device. (Confused yet?)
Options saved with each tool are stored as individual toolrc files in the "tool-options" directory. Options shared between all tools are stored in the "contextrc" file. Options saved with each input device are stored in the "devicerc" file.
Any one of the three can specify what the "current" colors/brush/gradient is, but the interactions between them are, in the exact words of a GIMP developer, "complicated, and difficult to get right".
In the meantime, if you add the "Device Status" window to one of your toolboxes you will see exactly which options are assigned to what device.
Separate tools per device is a VERY important thing to have, because this is what allows the pen and eraser tips of a tablet stylus to function as different tools (e.g. brush and eraser). On the other hand, separate colors/brush/pattern/gradient per device is nowhere near as important, and depending on your workflow it can even be something of a bother.
Of course, in your GIMP preferences you'll find options to share the current brush, dynamics, pattern and gradient between "all tools" - but there is no way to share these same things between all input devices. Why is that? Couldn't that be made user configurable?
Mikael Ståldal
2012-07-26 19:46:24 UTC (about 13 years ago)
Yes, I agree.
> nowhere near as important, and depending on your workflow it can even be > something of a bother.
Exactly, this is what bothers me.
