correct reference for the Gimp ?
7 of 7 messages available
correct reference for the Gimp ? Lyerra 26 Jun 21:12
  correct reference for the Gimp ? Kevin Cozens 02 Jul 19:49
  correct reference for the Gimp ? Liam R E Quin 02 Jul 22:15
correct reference for the Gimp ? Liam R E Quin 02 Jul 23:46
correct reference for the Gimp ? Liam R E Quin 03 Jul 04:15
  correct reference for the Gimp ? Michael Schumacher 03 Jul 07:12
  correct reference for the Gimp ? Michael Schumacher 03 Jul 07:16
Lyerra
2012-06-26 21:12:03 UTC (almost 13 years ago)
Sorry for the silly question, but... I'm using the Gimp quite heavily in my Ph. D. thesis redaction. I wish to reference it in the bibliography, as it should be. What is the correct/proper way of doing that ? Thanks in advance.
Kevin Cozens
2012-07-02 19:49:43 UTC (almost 13 years ago)
I would suggest you check with your staff adviser to find out what they want to see. A good start would be to refer to the program as "GIMP". :-) A link to GIMP's website would be a good idea along with the number of the version of GIMP you are using.
Liam R E Quin
2012-07-02 22:15:48 UTC (almost 13 years ago)
Depends on your subject area - e.g. MLA has guidelines to referring to Web sites in references, and you tend to see something like,
[GIMP12] GIMP image editor http://www.gimp.org/ accessed July 2012
Liam
Liam R E Quin
2012-07-02 23:46:34 UTC (almost 13 years ago)
On Mon, 2012-07-02 at 18:47 -0400, Lyerra wrote:
I do not wish to refer to the website (although the reference will contain the website but that is a detail), but to the authors.
You'd have an awfully long reference if you named all the contributors. I'd suggest something like, "All who contributed towards the GIMP libre software image editing program."
Liam
Liam R E Quin
2012-07-03 04:15:00 UTC (almost 13 years ago)
On Mon, 2012-07-02 at 19:54 -0400, Lyerra wrote:
True, it would be long. But that list has to exist somewhere. Maybe I can refer to the list itself ? Is it somewhere in the license ? How can I refer to the GPL specific for GIMP ?
Help->about lists them, and the source has an AUTHORS file that may or may not be included (it's in /usr/share/doc/gimp/AUTHORS here, on Linux).
I do not know how complete it is, as probably thousands of people have submitted small patches and are not mentioned.
Liam
2012-07-03 07:12:02 UTC (almost 13 years ago)
-------- Original-Nachricht --------
Datum: Tue, 03 Jul 2012 00:15:00 -0400 Von: Liam R E Quin
An: Lyerra
CC: gimp-user-list@gnome.org
Betreff: Re: [Gimp-user] correct reference for the Gimp ?
can
refer
Liam
-- Liam Quin - XML Activity Lead, W3C, http://www.w3.org/People/Quin/ Pictures from old books: http://fromoldbooks.org/ Ankh: irc.sorcery.net irc.gnome.org freenode/#xml
2012-07-03 07:16:31 UTC (almost 13 years ago)
Von: Liam R E Quin
If the point of the thesis isn't to extract this data from the source repository itself, then I'd rely on e.g. https://www.ohloh.net/p/gimp
Especially https://www.ohloh.net/p/gimp/contributors
HTH, Michael
