Adjusting Colors But Not Whites
Adjusting Colors But Not Whites Frank Gore 29 Jun 19:44
  Adjusting Colors But Not Whites Ofnuts 29 Jun 20:03
   Adjusting Colors But Not Whites Frank Gore 30 Jun 02:03
  Adjusting Colors But Not Whites Liam R E Quin 29 Jun 21:25
Frank Gore
2012-06-29 19:44:46 UTC (almost 13 years ago)
I have a set of icons which are a specific color (blue) with white text on them. I want to change them to be a different color (turquoise) and a fair bit darker, but I want the text to remain white. When I use Colors -> Hue-Saturation, I can get the desired color I want, but the text ends up looking grey because I need to bring down the lightness slider to achieve the color I want. Is there a better way to accomplish the task I need without affecting the white?
Frank Gore
THE place to talk photography!
www.FriendlyPhotoZone.com
2012-06-29 20:03:38 UTC (almost 13 years ago)
- make sure you have an alpha channel - use Colors/Color to alpha to make the white completely transparent - insert a white layer below: you now have the same icon but split on two layers
- select the layer with the remaining blue icon - at top of the layer list, check the alpha-lock box:painting on the layer will not change the transparency of the pixels. - paint that layer in any color you wish (you can even bucket-fill the whole layer)
It's really simpler than it looks, and the result will be about perfect.
See
for an explanation of the magic.
Liam R E Quin
2012-06-29 21:25:14 UTC (almost 13 years ago)
First, best is to keep the text as a text layer if it's not too late, and to work on the blue layer separately.
Second, colours->map has rotate colours, and that combined with using curves to make the image darger without moving the white point, is pretty easy and doesn't involve making new layers.
Liam
Frank Gore
2012-06-30 02:03:01 UTC (almost 13 years ago)
That worked perfectly, thank you.
-- Frank Gore
