newbie trouble needs to fit canvas
10 of 10 messages available
newbie trouble needs to fit canvas Madhatter 22 Jun 08:28
  newbie trouble needs to fit canvas Christen Anderson 22 Jun 13:14
   newbie trouble needs to fit canvas Olivier 22 Jun 13:31
    newbie trouble needs to fit canvas Christen Anderson 22 Jun 14:22
     newbie trouble needs to fit canvas Olivier 22 Jun 14:42
      newbie trouble needs to fit canvas Christen Anderson 22 Jun 14:57
  newbie trouble needs to fit canvas Ofnuts 23 Jun 12:29
  newbie trouble needs to fit canvas Liam R E Quin 24 Jun 04:09
   newbie trouble needs to fit canvas Madhatter 25 Jun 06:18
   newbie trouble needs to fit canvas Madhatter 25 Jun 06:28
2012-06-22 08:28:09 UTC (almost 13 years ago)
I have a square picture with a blank background. I would like to cut off the background so that i only have the real picture in the file (so that background will show around my picture when i use it on a homepage) could somebody please give me a little direktions... i know this is a real newbie problem but i dont know where to begun
regards Morten
Christen Anderson
2012-06-22 13:14:38 UTC (almost 13 years ago)
If I understand what you're talking about, the "crop" functionality in the "Tools" pane should do the trick =)
~Christen
regards Morten
Olivier
2012-06-22 13:31:52 UTC (almost 13 years ago)
Maybe he would rather want to use Image: Colors -> Color to Alpha and save the image in PNG. This suggestion would work for removing the white background and replacing it with transparency. Then any decent browser would show the webpage in the transparent areas.
2012/6/22 Christen Anderson :
~Christen
regards Morten
gimp-user-list@gnome.org
Christen Anderson
2012-06-22 14:22:04 UTC (almost 13 years ago)
True... but wouldn't it be easier to just crop it out as I suggested, then embed it in the webpage? Idk.. I don't know much about web design, and what little I do know hasn't been used in several months... so maybe I'm wrong...
Christen
Olivier
2012-06-22 14:42:44 UTC (almost 13 years ago)
If his "real picture", as he says, is rectangular, then the crop tool is okay. My suggestion is in the case his picture is not rectangular, say a person photographed on a white background. Replacing this white color with transparency will allow the webpage to be seen behind the picture.
Olivier Lecarme
gimp-user-list mailing list
Christen Anderson
2012-06-22 14:57:27 UTC (almost 13 years ago)
On 6/22/2012 8:42 AM, Olivier wrote:
2012/6/22 Christen Anderson:
Olivier Lecarme
Oh... I see what you mean. Yes, that makes perfect sense... I had misunderstood what you were originally suggesting. =)
Christen
2012-06-23 12:29:40 UTC (almost 13 years ago)
Fastest technique if the background is uniform (pure color), and the outline of the subject is sharp:
- use magic wand to select backrground, with a low threshold - grow the selection by 2px
- Colors/Color to alpha (use backrground color) - Optional Layer/Autocrop and "Image/Fit canvas to layers" - Export as PNG
Liam R E Quin
2012-06-24 04:09:36 UTC (almost 13 years ago)
To remove a blank background, image->autocrop may do what you want. If not, you can use the crop tool.
Liam
2012-06-25 06:18:59 UTC (almost 13 years ago)
thanks for all the replies... i think i will make the background transparent that seems to fit what i want to do. but thanks all off you for your input
regards Morten
2012-06-25 06:28:48 UTC (almost 13 years ago)
just figured out a problem with changing the color to transparent... it is a pencil drawing so the image (which is a parrot so not rectangular) is the same color as the background. i think i will change the color off the parrot slightly and then make background transparrent
regards Morten
