greyscale in monchrome images
greyscale in monchrome images David 04 Jun 04:06
  greyscale in monchrome images Joao S. O. Bueno 04 Jun 04:27
David
2004-06-04 04:06:29 UTC (almost 21 years ago)
Hi. I've got B/W monochrome bmp files. Is there a way to change ... say a region which is a solid black filled rectangle to a rectange with only 75% of the pixels in 'black' state?
Thanks in advance for any suggestions.
david
Joao S. O. Bueno
2004-06-04 04:27:47 UTC (almost 21 years ago)
fastest way seem to be:
- select the region were you want to make this. - Float selection (selection->float) - reduce opacity on floated selection to 75% - change layer combination mode on floated selection to "dissolve" instead of "normal".
- anchor selection back.
david
