Need a script to output position of images within image.
2012-05-31 00:44:06 UTC (over 12 years ago)
I created a jigsaw puzzle from an image. All the pieces exist in different layer.
Is there a way to get the position of the pieces (a script or a menu command)? I realize I could use the ruler, however, I would like something that would be more exact and less tedious.
Thanks, Stephen
Chris Mohler
2012-05-31 00:58:45 UTC (over 12 years ago)
With only one image open, from the python-fu console:
img = gimp.image_list()[0]
for layer in img.layers: print layer.name, layer.offsets
Chris
Chris Mohler
2012-05-31 01:02:43 UTC (over 12 years ago)
I was curious to see how the forum has hooking to the mailing list these days, and I'm sad to report that it munged the spacing on that psuedo-code. You'd be better off subscribing to the mailing list directly. Anyway, it should be like:
Where means indent via Tab key or spaces.
Chris
Chris Mohler
2012-05-31 01:04:49 UTC (over 12 years ago)
Well, I give up. The forum ate that too.
Chris
2012-05-31 01:08:43 UTC (over 12 years ago)
Chris
Fantastic! that works.
Where is a good place to learn more about the functions that are accessible through scripts?
Stephen
Chris Mohler
2012-05-31 01:09:55 UTC (over 12 years ago)
Check Help->Procedure Browser
Chris
2012-05-31 01:11:21 UTC (over 12 years ago)
Chris
Thanks, I'll do that.
Chris Mohler
2012-05-31 01:13:53 UTC (over 12 years ago)
Also you can do stuff like this in the console:
dir(gimp)
img = gimp.image_list()[0] dir(img)
etc.
Chris
2012-05-31 01:27:30 UTC (over 12 years ago)
dir(gimp)
dir(img)
etc.
Chris
Thanks.
Kevin Cozens
2012-05-31 16:35:42 UTC (over 12 years ago)
I'm not sure anything exists to do that but you could write a script. If you autocrop each layer you could then get the layer offset for each piece (ie. layer).
