Edit menu contents iin 2.8
Edit menu contents iin 2.8 Russ57 24 May 18:24
  Edit menu contents iin 2.8 luigi 24 May 18:40
   Edit menu contents iin 2.8 Russ57 26 May 15:04
  Edit menu contents iin 2.8 Ofnuts 24 May 22:42
  Edit menu contents iin 2.8 Michael Natterer 25 May 06:18
   Edit menu contents iin 2.8 Russ57 26 May 15:06
2012-05-24 18:24:35 UTC (almost 13 years ago)
Is it possible to edit the menu options to remove those items I will never use ? If so then how ?
luigi
2012-05-24 18:40:22 UTC (almost 13 years ago)
hi Russ,
i have gimp 2.6 for mac,one question,.. can you please say me if and where is it possible to download gimp 2.8.. for mac?
i can only find 2.6 version on theyr site. strange!
thanks.
Luigi
2012-05-24 22:42:07 UTC (almost 13 years ago)
I don't see a clean way without recompiling the app. Of course, for those that are implemented via plugins, removing the plugin (or making it non-executable on Unix-like platforms) should be enough... but there is the risk that this plugin is used under the hood by another plugin/script you use (even if this is not too likely for those of the "decorative" kind).
Michael Natterer
2012-05-25 06:18:35 UTC (almost 13 years ago)
Look into $prefix/share/gimp/2.0/menus/ and remove at will.
--Mitch
2012-05-26 15:04:59 UTC (almost 13 years ago)
sorry I am using Ubuntu 12.02
hi Russ,
thanks.
Luigi
2012-05-26 15:06:39 UTC (almost 13 years ago)
--Mitch
Tx Mitch - will give it a go
Russ
