Color -> transparency
Color -> transparency Egon Brinken 02 Jun 20:56
  Color -> transparency Andrew Gaffney 02 Jun 20:55
   Color -> transparency Egon Brinken 03 Jun 13:15
  Color -> transparency Irek Slonina 02 Jun 21:00
Color -> transparency William Skaggs 02 Jun 21:59
Andrew Gaffney
2004-06-02 20:55:20 UTC (almost 21 years ago)
Egon Brinken wrote:
I have a gif-picture, with two layers. The one transparent.
How can I subtract one specific color from the picture layer, e.g. let the uniform colored background be replaced by transparency? (The resulting picture must be saved as a gif-file, I presume. It shall be used on my web-pages)
The way I've found is to Select by Color using the background, Invert the selection, Copy, and Paste into a new image with a Transparent background.
Egon Brinken
2004-06-02 20:56:18 UTC (almost 21 years ago)
Egon
Irek Slonina
2004-06-02 21:00:02 UTC (almost 21 years ago)
(I haven't got English locales then the names could be a bit different)
Plug-ins->Colors->Color to alpha. Copy your color of the background to the box and you have what you wanted.
br.
William Skaggs
2004-06-02 21:59:09 UTC (almost 21 years ago)
The "Color to Alpha" filter does exactly what you want -- access it using the menu path "Filters -> Colors -> Color to Alpha".
Best, -- Bill
Egon Brinken
2004-06-03 13:15:57 UTC (almost 21 years ago)
Thanx. But I am relatively newbie. When I have selected by colour (Shift-O), the menu choice for inversion (Ctrl-I) is not active.
I would highly appreciate if you could explain me using "teaspoons". NB it is MY fault, not yours.
Yours sincerely Egon B
