resize, shear, perspective tools and popup
resize, shear, perspective tools and popup Gergely Kontra 01 Jun 15:39
  resize, shear, perspective tools and popup Sven Neumann 01 Jun 18:43
Gergely Kontra
2004-06-01 15:39:51 UTC (almost 21 years ago)
Hi!
Can I somehow supress the popup window, which appears, when I start to use the shear/perspective/rotate tools? It is very annoying, and prevents me to use it effectively.
Gergo
2004-06-01 18:43:01 UTC (almost 21 years ago)
Gergely Kontra writes:
No, but you can move it to the corner of the screen and have it pop up there again next time. Also you can configure your window manager not to give focus to this window (it can be identified by the WM_WINDOW_ROLE).
See also http://bugzilla.gnome.org/show_bug.cgi?id=137273
