Gimp-2.0 text tool problems
Gimp-2.0 text tool problems Dave S 30 May 09:14
  Gimp-2.0 text tool problems Sven Neumann 30 May 12:46
   Gimp-2.0 text tool problems Dave S 30 May 14:55
Dave S
2004-05-30 09:14:41 UTC (almost 21 years ago)
Im finding my way around Gimp-2.0 but have a couple of queries about the text tool..
Firstly, how do you create text at an angle, on gimp 1.2.3 it had an angle dialogue in the dyntext dialogue, I cannot find one in gimp-2.0.
Secondly (& this is driving me mad !) Once the text has been entered, you cannot just grab and move it,
you have to select the layer, select move, then move it. If its the wrong size, you have to re-select the layer, T then select the text, then adjust the font, colour.... Is there an easier way that I have overlooked ?
Any advice gratefully recieved
Cheers Dave
PS Gimp 2.0 is great ! I love it.
2004-05-30 12:46:45 UTC (almost 21 years ago)
Dave S writes:
Rotated text will hopefully be included in gimp-2.2. If you need rotated text with gimp-2.0, I suggest you use the Freetype plug-in (see http://freetype.gimp.org/).
Secondly (& this is driving me mad !) Once the text has been entered, you cannot just grab and move it, you have to select the layer, select move, then move it. If its the wrong size, you have to re-select the layer, T then select the text, then adjust the font, colour.... Is there an easier way that I have overlooked ?
The plan is to allow to move the text layer using the text tool but that's not yet implemented. For now you can use the Space key to temporarily switch to the move tool. That's not ideal but it makes things easier.
Dave S
2004-05-30 14:55:47 UTC (almost 21 years ago)
Sven Neumann wrote:
Dave S writes:
Thanks for the tips .... I will give them a go.
Gimp 2.0 is amazing & I am sure these few glitches will be sorted soon
Cheers Dave
