Help! Problem with gimp-curves-spline procedure
Help! Problem with gimp-curves-spline procedure Adir Kol 09 May 10:44
  Help! Problem with gimp-curves-spline procedure Kevin Cozens 09 May 15:56
   Help! Problem with gimp-curves-spline procedure Adir Kol 09 May 19:50
Adir Kol
2012-05-09 10:44:30 UTC (almost 13 years ago)
Hi All,
I've been trying to make gimp-curves-spline get variable (which is number) instead of number and I get error.
For example - when I do:
*(gimp-curves-spline drawable 0 6 #(0 0 0 15 255 255))*
everything works well as it should be.
but if I do: *(define spoint 15)*
*(gimp-curves-spline drawable 0 6 #(0 0 0 spoint 255 255))*
I get an error: *Error: Item 4 in vector is not a number (argument 4 for function gimp-curves-spline) #( 0 0 0 spoint 255 255 )* As you can see, all I did was replacing the number 15 with a variable (which is a number)
I also check it is a number by the *number?* type predicate
Any thoughts?
Kevin Cozens
2012-05-09 15:56:44 UTC (almost 13 years ago)
Putting a variable name in a list (or vector in this case) and expecting the value held by the variable to become part of the list (or vector) is an often made error when writing Scheme scripts. The syntax #( objects ) is a vector containing the listed objects. It is *not* an expression that evaluates to a list. To put it another way, it will not use the value or contents of "spoint" in the vector. The "spoint" reference was treated as a symbol.
It is easy to solve the problem by using the "list" procedure, but in your case you want a vector so you need one additional procedure call.
Use the following: (list->vector (list 0 0 0 spoint 255 255))
Adir Kol
2012-05-09 19:50:48 UTC (almost 13 years ago)
Thanks Kevin!
This would be the 2d time you're helping me :)
-- Cheers!
Kevin.
http://www.ve3syb.ca/ |"Nerds make the shiny things that distract
Owner of Elecraft K2 #2172 | the mouth-breathers, and that's why we're
| powerful!" #include | --Chris Hardwick ______________________________**_________________ gimp-user-list mailing list
gimp-user-list@gnome.org
http://mail.gnome.org/mailman/**listinfo/gimp-user-list
