Ppm 16bit handling
7 of 7 messages available
Ppm 16bit handling bruno@buys.net.br 07 May 03:57
  Ppm 16bit handling Kevin Cozens 07 May 06:44
  Ppm 16bit handling Simon Budig 07 May 09:04
   Ppm 16bit handling bruno@buys.net.br 24 May 02:34
    Ppm 16bit handling Liam R E Quin 24 May 03:23
    Ppm 16bit handling Simon Budig 24 May 08:27
     Ppm 16bit handling bruno@buys.net.br 24 May 14:21
bruno@buys.net.br
2012-05-07 03:57:21 UTC (about 13 years ago)
Ppm 16bit handling
Hi all,
I noticed that when I open a 16bit ppm in GIMP 2.8, the file opens without the 'gimp can't handle 16bit, it will loose data, etc...' notification. But if I open a tiff version of the very same raw file, the notification does pop up. My understanding is that current GIMP 2.8 can't handle 16bit, regardless of file format. Is that right?
Bruno Buys
Kevin Cozens
2012-05-07 06:44:29 UTC (about 13 years ago)
Ppm 16bit handling
Correct.
Simon Budig
2012-05-07 09:04:36 UTC (about 13 years ago)
Ppm 16bit handling
Yes, these warning dialogs are generated by the file-format plugin and it seems the ppm plugin just silently discards data.
Gimp 2.8 is limited to 8 bit per channel, but if you feel adventurous you are invited to try the current git version of babl/gegl/gimp and experiment with the new high-bit-depth support. This still is strictly unstable and has an inconsistent UI in lots of places. It is fun though :)
I hope this helps,
Simon
bruno@buys.net.br
2012-05-24 02:34:29 UTC (about 13 years ago)
Ppm 16bit handling
I hope this helps,
Simon
So after a bunch of package installing and compiling, I am successfully running Gimp 2.9.1 from git, on debian wheezy. The thing is, when I open a 16bit tiff, Gimp *still* pops up the "can't handle 16bit,
information will be lost...". After opening the file I go to Image > Precision and change
to 16bit. But from what I understand, setting the file to 16bit *after* it was downed
from 16 to 8 doesn't help. Information was already discarded in the first conversion.
I don't understand: can't Gimp just open the file as it is, with no conversion whatsoever, since
support to 16bit is there?
Thanks much,
Bruno
Liam R E Quin
2012-05-24 03:23:50 UTC (about 13 years ago)
Ppm 16bit handling
On Wed, 2012-05-23 at 23:34 -0300, bruno@buys.net.br wrote:
I don't understand: can't Gimp just open the file as it is, with no conversion whatsoever, since support to 16bit is there?
Yes - all it takes is programming, code to handle each format at higher bit depths. Patches are generally welcomed...
Liam
Simon Budig
2012-05-24 08:27:30 UTC (about 13 years ago)
Ppm 16bit handling
The thing is, when I open a 16bit tiff, Gimp *still* pops up the "can't handle 16bit, information will be lost...". After opening the file I go to Image > Precision and change to 16bit. But from what I understand, setting the file to 16bit *after* it was downed from 16 to 8 doesn't help. Information was already discarded in the first conversion.
I am working at the TIFF plugin and some tiffs get loaded correctly (while others are broken at the moment). Tiff is quite convoluted and has a ton of different options. It is hard to wrap your mind around it.
Well, unfortunately it is not that easy. There is a certain API available for the file-plugins that transfers the image data to the Gimp core. That API was only prepared to accept 8 bit images. The transition of the core to a wider range of data formats did not change the old API, since we wanted to keep compatibility for the plugin (or all plugins would have disappeared simultaneously).
Hence we had to invent a second set of API functions that support the new data formats. However, this means that the plugins which want to make use of the new data formats need to be changed to use the new API. In a lot of cases this is quite easy and means less code in the plugins, but the changes have to be done and it is real work.
Porting the p*m-Plugin (plug-ins/common/file-pnm.c) should be easy. The file-format is as simple and straight-forward as it gets. If you want to dabble with development and help with the progress of Gimp you are welcome to take a shot at it. If you catch me in IRC (#gimp, nomis) I'll be glad to give assistance.
Have fun, Simon
bruno@buys.net.br
2012-05-24 14:21:45 UTC (about 13 years ago)
Ppm 16bit handling
On Thu, 24 May 2012 10:27:30 +0200, Simon Budig wrote:
bruno@buys.net.br [1] (bruno@buys.net.br [2]) wrote:
The thing is,
I am
(while
has a
Well,
available
core.
of
new data formats.
make use of the new
In a lot of cases
but the changes
file-format is as
dabble with
welcome to take
be glad to
give assistance.
Have fun,
Simon
Hi Simon!
That´s very friendly
of yours to reply in such detail. Now I feel like my first email was a
little "clientish". Sorry for that. Gimp isn´t a private company.
I am not of much help as a coder, but I can provide files and give feedback
in testing.
Good news is, since you said you are working in 16bit tiff, when its done,
it will be huge. Tiff is an important bridge for those of us converting from raw.
Other good news is, I was able to load, work and save a 16bit png file, following this
post:
http://libregraphicsworld.org/blog/entry/gimp-2.8-released-next-version-to-get-high-bit-depth-precision
The file was converted from tiff to png with 'convert', and opens without the
loose data notification. After opening, the precision is indeed set to 16bit.
All the best!
Bruno
Links: ------
[1]
mailto:bruno@buys.net.br
[2] mailto:bruno@buys.net.br
