Problem with Gimp 2.7.4 'Text'
Problem with Gimp 2.7.4 'Text' Maurice 05 May 10:29
Maurice
2012-05-05 10:29:44 UTC (almost 13 years ago)
On 2012-05-04 at 20:14 someone said:
mageMagick wil do it:
http://www.imagemagick.org/Usage/text/#text_operators
Command-line functions are no good for this job. You need to be looking at the image, so that you can:
(1) See what the annotation should be (2) See that the text is positioned correctly, and of suitable size and font.
Gimp is (was) perfect for that - simple and smooth.
In case I can't find a suitable GUI alternative, I have put a block on any further updates to Gimp on Mandriva.
