Misc RC (noob) problems
Misc RC (noob) problems Madeleine Fisher 26 Apr 01:17
Misc RC (noob) problems Kevin Brubeck Unhammer 26 Apr 17:58
Madeleine Fisher
2012-04-26 01:17:46 UTC (almost 13 years ago)
I just downloaded the new RC, and it works really well, but I have a problem--when I use my tablet and it goes off the screen, the pressure settings will suddenly switch off. Is that something that I can fix? Or will it work better in future releases? Some with the free-move (or whatever)--when I move the view around sometimes I have to minimize the whole GIMP to get it to refresh properly.
Also, just if anybody has any good advice: sometimes when I hit the hotkeys I hit my mousepad, too (on my laptop), and GIMP will sporadically spaz between the "default" settings and the one's I've put on my tablet to draw with at the current moment. I wouldn't ask for help, but it continues for minutes afterward sometimes. It makes it difficult to draw a line and is just kind of annoying. Any thoughts?
PS These are small problems, and overall I'd like to thank the GIMP guys so much for the update. The improved dynamics have really helped me out at my job.
2012-04-26 17:58:16 UTC (almost 13 years ago)
Madeleine Fisher writes:
Hmm, this seems like something for the devs … If you feel like contributing a bug report, http://www.gimp.org/bugs/ has some info; there's also the gimp developer list at http://blog.gmane.org/gmane.comp.video.gimp.devel
If it were me, I would run a program that turns on/off the mousepad with a global hotkey (so I could press e.g. F12 or something to toggle it). Depends on your system how easy it is to find such a program though …
-Kevin
