Fwd: issues with gimp on mac 10.7.3
Fwd: issues with gimp on mac 10.7.3 Partha Bagchi 04 Apr 22:35
Partha Bagchi
2012-04-04 22:35:26 UTC (about 13 years ago)
Sorry, sent only to the person below by mistake.
---------- Forwarded message ---------- From: Partha Bagchi
Date: Wed, Apr 4, 2012 at 6:28 PM
Subject: Re: [Gimp-user] issues with gimp on mac 10.7.3 To: rcook@pcug.org.au
On Wed, Apr 4, 2012 at 5:38 PM, Owen wrote:
I have made a few attempts to install Gimp but I'm having the same problems. I continually get a message about my swap file:
To avoid data loss, please check the location and permissions of the swap directory defined in your Preferences (currently "/Users/helenebrennan/Library/Application Support/Gimp").--
All permissions are open, but I can find no such directory
Also:
Failed to create thumbnail folder '/Users/helenebrennan/Library/Application Support/Gimp/cache/thumbnails/normal'.
I have not been able to fix these problems. Please can you help.
This is linux? windows?
Can you go to preferences and try another swap location. Try /Users/helenebrennan
Owen
gimp-user-list@gnome.org
Seriously?? She says trouble on Mac and you ask if this is Windows or Linux??
Helene, can you use the file finder to see if the your local Gimp folder is actually located in your local Library/Application Support/ folder?
gimp-user-list mailing list
