Gimp (pre)view window for transparent images
Gimp (pre)view window for transparent images Renato Alves 15 Mar 12:58
  Gimp (pre)view window for transparent images Ofnuts 16 Mar 09:45
Renato Alves
2012-03-15 12:58:24 UTC (about 13 years ago)
Hello everyone,
I'm trying to create icons (.ico) files in Gimp and I am looking for ways to preview the result directly in gimp.
To do this I'm currently using the "New view" functionality where I disable most things (layer boundary, rules...) to display the image in its original size (100% zoom). I also selected the Padding color according to the background of the image to visualize it in proper context.
The above setup works fine for images with a fixed background color, but not so much with images that have a transparent background.
From what I was able to figure out, the only place where you can customize how transparency is displayed is by going to Preferences > Display. However, changing these options affects all open windows an not just the current view. In addition, the possible choices for how transparency is displayed are somewhat limited (no colors other than white, gray and black).
With that said, is there any way of previewing the image while being able to customize how transparency is displayed?
Thanks Renato
2012-03-16 09:45:28 UTC (about 13 years ago)
On 03/15/2012 01:58 PM, Renato Alves wrote:
Hello everyone,
From what I was able to figure out, the only place where you can customize how transparency is displayed is by going to Preferences> Display. However, changing these options affects all open windows an not just the current view. In addition, the possible choices for how transparency is displayed are somewhat limited (no colors other than white, gray and black).
Nothing prevents you from adding a background layer for your test and discarding it (or making it invisble) before exporting the ICO file. For that kind of work I test the picture against several backgrounds (at least a dark and a light one) anyway.
