Opening .cdr and .cpt
1 of 8 messages available
Pine.LNX.4.33.0209241511330... 05 Mar 16:52
Pine.LNX.4.33.0209251150500... 05 Mar 16:52
3D90C2FB.3070405@softhome.net 05 Mar 16:52
3D91E2E6.9000609@softhome.net 05 Mar 16:52
1032979154.1629.8.camel@aen... 05 Mar 16:52
3D9218E6.5020205@softhome.net 05 Mar 16:52
4f54ef418a24d_109b14008c31c... 05 Mar 23:01
Opening .cdr and .cpt Kevin Brubeck Unhammer 06 Mar 08:58
2012-03-06 08:58:24 UTC (about 13 years ago)
Steve Kinney writes:
On 03/05/2012 11:52 AM, promovis wrote:
Download Uniconvertor, convert your cdr to svg, edit svg with Gimp. Good luck!
You might also want to give Inkscape a try - it's a native SVG editor. The best you can do with the GIMP is convert the SVG file from vector format to a bitmap format, and presumably there was a reason of some sort for creating a vector based file in the first place.
There's also sk1, the program from which UniConvertor spawned: http://libregraphicsworld.org/blog/entry/sk1-development-restarted
I haven't tried it myself, but it may be interesting; likely more suitable for vector graphics than GIMP anyway. Does CMYK.
-Kevin
