moving floating layers (was: Trying to move layer; only outline will move)
moving floating layers (was: Trying to move layer; only outline will move) Kevin Brubeck Unhammer 03 Mar 22:25
  moving floating layers Burnie West 04 Mar 00:19
2012-03-03 22:25:29 UTC (about 13 years ago)
"Dan ." writes:
Hi Kevin,
From my experience, after pasting a new object in order to create a new layer, in the layers menu there should be Floating Selection ("pasted Layer") like Burnie wrote. For me, I right-click the "pasted layer" and select "New Layer", and the pasted object shows up as a new layer. From there, I make sure I deselect everything (SELECT > NONE), and then use the move tool (making sure the cursor is over the pasted object) to click on the object in your new layer in order to move it. Hope that is of some help.
You can move it first too though (then press ctrl+shift+N to turn it into a regular layer). I find that quicker, but whatever floats your boat. Layer. Whatever.
-k
Burnie West
2012-03-04 00:19:12 UTC (about 13 years ago)
On 03/03/2012 02:25 PM, Kevin Brubeck Unhammer wrote:
"Dan ." writes:
Hi Kevin,
From my experience, after pasting a new object in order to create a new layer, in the layers menu there should be Floating Selection ("pasted Layer") like Burnie wrote. For me, I right-click the "pasted layer" and select "New Layer", and the pasted object shows up as a new layer. From there, I make sure I deselect everything (SELECT> NONE), and then use the move tool (making sure the cursor is over the pasted object) to click on the object in your new layer in order to move it. Hope that is of some help.
In my experience, there are many instances wherein actions involving a Floating Selection behave differently than those involving individual (properly "anchored") layers. I chose to describe this approach because Kevin had (possibly) run into such a case.
- Burnie
