Trying to move layer; only outline will move
7 of 7 messages available
Trying to move layer; only outline will move Keith Purtell 02 Mar 15:08
  Trying to move layer; only outline will move Burnie West 02 Mar 15:34
  Trying to move layer; only outline will move Alexandre Prokoudine 02 Mar 15:37
   Trying to move layer; only outline will move Keith Purtell 02 Mar 15:57
Trying to move layer; only outline will move Kevin Brubeck Unhammer 03 Mar 14:28
  Trying to move layer; only outline will move Dan . 03 Mar 18:42
   Trying to move layer; only outline will move althumbs 02 Jul 18:53
Keith Purtell
2012-03-02 15:08:55 UTC (about 13 years ago)
- ! 'I''ve read the official tutorial several times and yet the directions aren''t
working for me. I pasted in a layer which shows up fine in the layers box.
The active layer is the one I pasted in. The Move tool is set to "Move the
active layer." I''ve tried using the Move tool by both dragging and clicking
and dragging. In either case, the new layer doesn''t move, only the outline
(marching ants). I''ve got a huge project to complete today and can''t spend
an hour just trying to get GIMP to move a layer. Tips?
Keith'
Burnie West
2012-03-02 15:34:09 UTC (about 13 years ago)
- ! "On 03/02/2012 07:08 AM, Keith Purtell wrote:\n> I've read the official tutorial several times and yet the directions aren't \n> working for me. I pasted in a layer which shows up fine in the layers box. The \n> active layer is the one I pasted in. The Move tool is set to \"Move the active \n> layer.\" I've tried using the Move tool by both dragging and clicking and \n> dragging. In either case, the new layer doesn't move, only the outline \n> (marching ants). I've got a huge project to complete today and can't spend an \n> hour just trying to get GIMP to move a layer. Tips?\n> Keith\nThe newly pasted layer must be anchored before it can be moved. Your layers menu \nlikely shows the words Floating Selection (\"pasted Layer\") If so, then the layer \nmust be be anchored first. Under the layer menu, select \"Anchor Layer\"\n\n - Burnie\n\n"
2012-03-02 15:37:39 UTC (about 13 years ago)
> (marching ants).
Marching ants means you have an active selection. Get rid of it.
Select > None
http://libregraphicsworld.org
Keith Purtell
2012-03-02 15:57:01 UTC (about 13 years ago)
- ! 'On Fri, Mar 2, 2012 at 9:37 AM, Alexandre Prokoudine <
> outline
> > (marching ants).
> Select > None
I will do that; thank you!'
2012-03-03 14:28:02 UTC (about 13 years ago)
Burnie West writes:
I've read the official tutorial several times and yet the directions aren't working for me. I pasted in a layer which shows up fine in the layers box. The active layer is the one I pasted in. The Move tool is set to "Move the active layer." I've tried using the Move tool by both dragging and clicking and dragging. In either case, the new layer doesn't move, only the outline (marching ants). I've got a huge project to complete today and can't spend an hour just trying to get GIMP to move a layer. Tips?
Keith
The newly pasted layer must be anchored before it can be moved. Your layers menu likely shows the words Floating Selection ("pasted Layer") If so, then the layer must be be anchored first. Under the layer menu, select "Anchor Layer"
Not on my GIMP … I move around floating layers all the time. I'm pretty sure «Select → None» is the solution.
-k
Dan .
2012-03-03 18:42:19 UTC (about 13 years ago)
Hi Kevin,
From my experience, after pasting a new object in order to create a new layer, in the layers menu there should be Floating Selection ("pasted Layer") like Burnie wrote. For me, I right-click the "pasted layer" and select "New Layer", and the pasted object shows up as a new layer. From there, I make sure I deselect everything (SELECT > NONE), and then use the move tool (making sure the cursor is over the pasted object) to click on the object in your new layer in order to move it. Hope that is of some help.
Dan
On Sat, Mar 3, 2012 at 6:28 AM, Kevin Brubeck Unhammer wrote:
Burnie West writes:
Keith
-k
gimp-user-list@gnome.org
2013-07-02 18:53:28 UTC (almost 12 years ago)
Hi Kevin,
Dan
When you select the move tool, look at the options (just below or lower half of the tool selection right side of screen). You will see three buttons next to "Move:" mouse over it says', Layer, selection, and path. Click layer. This get me every time.
wrote:
