Problem installing GimpLensFun
Problem installing GimpLensFun Leonard Evens 19 Feb 16:44
  Problem installing GimpLensFun Patrick Shanahan 19 Feb 20:00
Problem installing GimpLensFun Leonard Evens 19 Feb 21:08
Leonard Evens
2012-02-19 16:44:34 UTC (about 13 years ago)
I've been using GimpLensFun with gimp 2.2.6.11 under Fedora 14. It appears under Filter>Enhance.
I just installed Fedora 15 on another computer. There is the added complication of Gnome 3, which I have yet to master, but that shouldn't make any real difference.
I tried to install GimpLensFun on the new computer which is running gimp 2.6.12. I downloaded the tar file and copied GimpLensFun for AMD 64 bit, which is the correct computer, into .gimp-2.6/plugins
But I can't find GimpLensFUn in any filter or anywhere else.
What is wrong?
Added later: On the old system, gimplensfun occurs in pluginrc, but it doesn't in the
new system, either in that form or as GimpLensFun.
Patrick Shanahan
2012-02-19 20:00:27 UTC (about 13 years ago)
* Leonard Evens [02-19-12 12:37]:
It's under Filters -> Enhance -> GimpLensFun in my openSUSE 12.2 gimp 2.6.12.
Leonard Evens
2012-02-19 21:08:10 UTC (about 13 years ago)
What is wrong?
Added later:
At the suggestion of the author, instead of using the version provided in bin/linux, I recompiled the plug-in by using make. I copied the resulting binary named gimplensfun into ~/.gimp-2.6/plug-ins, and after restarting gimp, it worked.
