Gimp and web site design.
Gimp and web site design. John Culleton 09 May 19:39
  Gimp and web site design. Michael Schumacher 09 May 14:23
  Gimp and web site design. GSR - FR 09 May 17:19
  Gimp and web site design. David Neary 09 May 18:06
   Gimp and web site design. GSR - FR 09 May 19:17
2004-05-09 14:23:28 UTC (almost 21 years ago)
John Culleton wrote:
I found the comments below from a friend of mine on another list provaocative. She is not a Gimp user. I wonder how many of her cautions are universal and how many just dependent on the program used to create the graphics? -----quote begins-----------
I visit lots of authors' sites and see many that are gorgeous. The thing that always tips me off as to whether they're professionally done or not is the graphics. I cannot stand jagged edges around images, banners, etc. Even the most inexperienced designer can clean that up and do it properly at low resolution, so, I guess it's not so much that it's a sign of being an amateur - to me anyway - that it's a sign of not caring....lack of pride in the work.
Well, if someone cannot stand jaggies at edges, this is a mere subjective impression. However, many people think like this, so it might be a good idea to create smooth edges if you don't want jaggies intentionally.
Even if a person simply cannot create clean edges (one of the most common mistakes is using "tansparent" on a layer - transparent doesn't work..you need to use the background colour as the background colour on the image around any curved lines. Also that "delete" background rarely gives a clean lift - that all needs to be erased one pixel at a time.) they can go with text only, or visit one of the 1000s of sites that offer free web tools, or avoid curved edges (in most cases jaggies are only an issue around curved edges). Round
buttons only look nice if they're done properly. Square (with no transparency and no background) and text buttons work just as well and will give a more "polished" look.
The term "transparency" here is ambiguous - from the text, it seems like your friend talks about the kind of transparency used in e.g. GIF - either full or no transparency.
When using a full alpha channel, things are different.
I'm not a web designer by any means, so maybe those on the group who are can offer more insight into this.
-----------end quote BTW I have permission to quote the above from the author.
All the cautions do not really depend on the program used to create the images - unless you decide to use a paint program only capable of 16 colors ;) I don't think any real image editing software can't do the things your firend describes.
They do however strongly depend on the program used to view the graphics. When talking about the web, this means web browsers.
HTH, Michael
GSR - FR
2004-05-09 17:19:54 UTC (almost 21 years ago)
john@wexfordpress.com (2004-05-09 at 0739.12 -1000):
All apps I know can do it, of course people just have to know what is going on. Also, it would be a lot simpler if some web browsers did it right to begin with and transparency worked in them as it should.
GSR
David Neary
2004-05-09 18:06:45 UTC (almost 21 years ago)
Hi John,
I wonder how
Her comments on web graphics are, IMHO, universal, as opposed to limited to one program or another.
This is a fair comment. Transparency (in GIF, and as supported by IE in indexed PNGs) is limited to one palette entry which is completely transparent, and the rest completely opaque. Usually, smooth rounded edges are obtained by antialiasing the curve, going in grades from opaque to transparent over a number of pixels. Since you can't antialias to transparent in gif, round edges usually look crap. However, if you have a background that isn't transparent, then you can antialias from white to green, say, just fine, and have some of that smoothness kept across an indexing operation.
However, PNG supports indexing much more advanced than that - essentially, an indexed palette entry in png has an alpha component, so with indexed png you can antialias to transparent. However, this isn't supported in IE for Windows. You can also use 32 bit PNG which is funny supported on both IE and Mozilla, but is a much larger file size.
Cheers, Dave.
GSR - FR
2004-05-09 19:17:12 UTC (almost 21 years ago)
dneary@free.fr (2004-05-09 at 1806.45 +0200):
GIMP does not support indexed RGBA (palette items are four channels, so all can have some level of transparency, vs typical GIF's "one colour is transp only") and dunno which tool does it. But there typical problem is that IE does not support 32 bit PNG as it should, that is, without tricks (some pretty complex). For simplest trick see: http://www.phoenity.com/newtedge/png_degradability/
GSR
John Culleton
2004-05-09 19:39:12 UTC (almost 21 years ago)
I visit lots of authors' sites and see many that are gorgeous. The thing that always tips me off as to whether they're professionally done or not is the graphics. I cannot stand jagged edges around images, banners, etc. Even the most inexperienced designer can clean that up and do it properly at low resolution, so, I guess it's not so much that it's a sign of being an amateur - to me anyway - that it's a sign of not caring....lack of pride in the work. Even if a person simply cannot create clean edges (one of the most common mistakes is using "tansparent" on a layer - transparent doesn't work..you need to use the background colour as the background colour on the image around any curved lines. Also that "delete" background rarely gives a clean lift - that all needs to be erased one pixel at a time.) they can go with text only, or visit one of the 1000s of sites that offer free web tools, or avoid curved edges (in most cases jaggies are only an issue around curved edges). Round
