paste in the same place as the copied selection was?
paste in the same place as the copied selection was? Matteo Sisti Sette 11 Feb 12:59
  paste in the same place as the copied selection was? Ofnuts 11 Feb 13:25
  paste in the same place as the copied selection was? Partha Bagchi 11 Feb 14:23
Matteo Sisti Sette
2012-02-11 12:59:40 UTC (about 13 years ago)
Let's say I have two images of the same size (e.g.800x600)
I select a region of the first image with any selection tool (e.g. the fuzzy select tool)
I copy the selection.
Isn't there a way to paste the selection into the second image at exactly the same position where it was in the first image??
It seems to me unbelievable that there is no such option, but I can't ind it. I must be missing it. In Adobe flash it is called "paste in situ".
Thanks in advance
m.
2012-02-11 13:25:58 UTC (about 13 years ago)
In the first image:
- Edit/Copy - Edit/Paste (in same image)
- New layer (new layer with pasted image part) - Layer/Layer to image size
- Select all
- Copy
- In target image:
- Edit/paste
In the general case (paste between two images of different sizes) it is not useful, because there is no simple definition of "at the same place". In this specific case, you can also "File/Open as layers" the source image into your target image and cut what your want... There is no need for two distinct images.
Partha Bagchi
2012-02-11 14:23:12 UTC (about 13 years ago)
Thanks in advance
m. _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
Why don't you make a layer and use a layer mask?
