GIMP 2.7, - 2 simple questions
11 of 11 messages available
GIMP 2.7, - 2 simple questions Kekko 07 Feb 13:15
  GIMP 2.7, - 2 simple questions Ofnuts 08 Feb 11:11
GIMP 2.7, - 2 simple questions Kevin Brubeck Unhammer 07 Feb 13:54
  GIMP 2.7, - 2 simple questions Kekko 07 Feb 19:32
   GIMP 2.7, - 2 simple questions Patrick Shanahan 07 Feb 20:04
    GIMP 2.7, - 2 simple questions Patrick Shanahan 07 Feb 20:07
     GIMP 2.7, - 2 simple questions Kekko 08 Feb 06:55
      GIMP 2.7, - 2 simple questions Patrick Shanahan 08 Feb 14:04
       GIMP 2.7, - 2 simple questions Kekko 08 Feb 17:46
        GIMP 2.7, - 2 simple questions Patrick Shanahan 08 Feb 19:01
    GIMP 2.7, - 2 simple questions Alexandre Prokoudine 08 Feb 02:25
2012-02-07 13:15:03 UTC (almost 13 years ago)
Hi everybody,
just two simple questions about GIMP 2.7.4 that I installed on Linux Ubuntu 11.10. 1. In previous versions of GIMP the shortcut ctrl+E allowed to put the image entirely in the frame while now ctrl+E is the command for exporting the image: do you know how to have a simple shortcut to replicate what ctrl+E did in 2.6 version? 2. Why the command "Save as" don't allow to save in jpg? Now we are forced to use Export in order to save an image in jpg format.
Thanks for your help. Ciao
Kekko
http://flic.kr/ps/mTWuo
2012-02-07 13:54:01 UTC (almost 13 years ago)
Kekko writes:
Hi everybody,
ctrl+J / ctrl+shift-J, according to http://www.gimp.org/release-notes/gimp-2.7.html
Yes, we are :) If you only work in JPG, just think of Export as saving, you can ignore the "save" menu item.
Some good reasons for splitting it in two items:
I at least prefer having both the full, untainted XCF available at all times, and once in a while I'll export to JPG/PNG, this used to require a lot of maintenance before, now I can just to ctrl+s or ctrl+e depending on whether I want to save or export.
Also, when saving as JPG etc. in 2.6, you would get a warning about how layer information is lost. This you don't get now, saving always preserves all information, it is assumed that when you export, you're aware that information is lost. It's a lot more honest, in my opinion.
2012-02-07 19:32:08 UTC (almost 13 years ago)
Thanks a lot.
I 'd like to do another little question. I have a Ubuntu PC in Italian language but I'd prefer to work in English GIMP. I saw I can launch GIMP from terminal typing "LANG=en gimp" but is there a way to have the same result launching it from the Icon? Thanks in advance for your help.
Francesco
Patrick Shanahan
2012-02-07 20:04:58 UTC (almost 13 years ago)
* Kekko [02-07-12 14:33]:
make a text file:
#!/usr/sh LANG=en /usr/bin/gimp
save file make file executable
chmod u+x
attach icon to file
clicking on the icon will start gimp with "LANG=en"
Patrick Shanahan
2012-02-07 20:07:00 UTC (almost 13 years ago)
* Patrick Shanahan [02-07-12 15:05]:
make a text file:
sorry, that s/b
#!/usr/bin/sh
save file
chmod u+x
attach icon to file
(paka)Patrick Shanahan Plainfield, Indiana, USA HOG # US1244711 http://wahoo.no-ip.org Photo Album: http://wahoo.no-ip.org/gallery2 http://en.opensuse.org openSUSE Community Member Registered Linux User #207535 @ http://linuxcounter.net _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
2012-02-08 02:25:46 UTC (almost 13 years ago)
On Wed, Feb 8, 2012 at 12:04 AM, Patrick Shanahan wrote:
make a text file:
2012-02-08 06:55:50 UTC (almost 13 years ago)
attach icon to filestinfo/gimp-user-list
Thanks, how can I attach the icon to the file? Sorry but I worked in Linux a lot of years ago when graphic interface was a dream. Ciao
2012-02-08 11:11:40 UTC (almost 13 years ago)
On 02/07/2012 02:15 PM, Kekko wrote:
Hi everybody,
Because prior to 2.7, if you edit a XCF, and "save as" JPEG/TIFF/PNG, the image is deemed saved and you can quit without being told you'll lose your work (which is the case, think about layers/selections/paths...). So now "Save/Save as" is restricted to XCF, and if you want to obtain a JPEG/TIFF/PNG you have to export. I believe there an exception to this, if the image is loaded from a non-XCF file you can still "Save" directly to that format.
Patrick Shanahan
2012-02-08 14:04:47 UTC (almost 13 years ago)
* Kekko [02-08-12 01:57]:
I really don't know *buntu* but in openSUSE: on script icon and then on the pop-up icon allows assinging a different icon.
Did you read Alexandre's post? He suggests just setting your lang pref in gimp's preferences and not jumping thru the other hoops.
2012-02-08 17:46:24 UTC (almost 13 years ago)
Ok thanks to everybody, I changed the language from prefrences also if the Alexandre's post is not completely visible. Ciao
Patrick Shanahan
2012-02-08 19:01:39 UTC (almost 13 years ago)
* Kekko [02-08-12 12:48]:
?? not visible ??
Maybe I can help you there. What doesn't show, how are you viewing it and what are you using to view it?
off-list.
