Gimp-2.7 Help/Manual?
10 of 10 messages available
Gimp-2.7 Help/Manual? gerard82 05 Feb 18:40
  Gimp-2.7 Help/Manual? Alexandre Prokoudine 05 Feb 18:57
  Gimp-2.7 Help/Manual? Gary Aitken 06 Feb 05:25
   Gimp-2.7 Help/Manual? gerard82 06 Feb 18:59
    Gimp-2.7 Help/Manual? Olivier 06 Feb 20:51
     Gimp-2.7 Help/Manual? gerard82 06 Feb 21:59
      Gimp-2.7 Help/Manual? Olivier 07 Feb 07:04
    Gimp-2.7 Help/Manual? Alexandre Prokoudine 07 Feb 07:16
     Gimp-2.7 Help/Manual? gerard82 07 Feb 13:47
      Gimp-2.7 Help/Manual? Olivier 07 Feb 14:01
2012-02-05 18:40:28 UTC (about 13 years ago)
I compiled Gimp-2.7.x from git sources. There are things in brush Tool Options not very clear to me. Is there any Help/Manual available for this version? If so where can I find it?
Thanks in advance.
Gerard.
2012-02-05 18:57:56 UTC (about 13 years ago)
No, we haven't really started documenting v2.8 yet. What's the issue with tool options exactly?
Gary Aitken
2012-02-06 05:25:29 UTC (about 13 years ago)
Try
http://docs.gimp.org/2.7/en/index.html
Thanks in advance.
Gerard.
2012-02-06 18:59:23 UTC (about 13 years ago)
Try
Thanks in advance.
Gerard.
In 2.6 you can click "Use color from gradient". This has gone from 2.7.x!
The only way you can paint with gradient is by choosing Random Color from the Dynamics dropdown menu. But the result is bad!!!
No smooth stroke no pressure.
Another way in which the brush uses gradient colors is "Confetti". Again no pressure sensitivity and unpredictable result. In this doc it is still there (scroll down to fig 7.25) http://docs.gimp.org/2.7/en/gimp-concep ... ients.html Gerard.
Olivier
2012-02-06 20:51:22 UTC (about 13 years ago)
Define your own paint dynamics, with a box checked in the Color row and the Pressure column.
2012/2/6 gerard82 :
Try
2012-02-06 21:59:40 UTC (about 13 years ago)
2012/2/6 gerard82 :
Try
Your talking about 2.6.
Gerard.
Olivier
2012-02-07 07:04:22 UTC (about 13 years ago)
No, I'm talking about 2.8 (or 2.7 from git sources). In 2.6 you cannot define your own paint dynamics.
2012/2/6 gerard82 :
2012/2/6 gerard82 :
Try
Gerard.
gerard82 (via gimpusers.com)
gimp-user-list@gnome.org
2012-02-07 07:16:58 UTC (about 13 years ago)
Moved, not gone.
Create a new paint dynamics definition, map Color to Fade, in brush settings choose a gradient. Then try it on canvas :)
2012-02-07 13:47:43 UTC (about 13 years ago)
Moved, not gone.
Thanks Alexandre.
When I open the dynamics editor I can go to color but everyhing is grayed out. Same for brush settings.
I looked in Edit>Preferences but couldn't find anything that should be set to enable/disable setting these. What am I doing wrong or what might be missing? I compiled babl,gegl and gimp from git.gnome.org and it all went w/o a hitch. I am using Gentoo Linux.
Gerard.
Olivier
2012-02-07 14:01:35 UTC (about 13 years ago)
You must create a new dynamic, you cannot change a system dynamic. Click the middle button in the bottom bar of the Paint Dynamics dialog.
2012/2/7 gerard82 :
Moved, not gone.
Thanks Alexandre.
Gerard.
