.GIF timing issue
.GIF timing issue adrian brisland 01 Feb 04:49
  .GIF timing issue Richard Gitschlag 01 Feb 18:24
adrian brisland
2012-02-01 04:49:06 UTC (about 13 years ago)
.GIF timing issue
To gimp-user list recipients,
I've run into a problem where I cant edit the delay between frames for my .GIF file. Im looking to set it it 41ms for each frame, which Ive done when prompted as I save my file, but the playback speed seems to stay at 100ms delay when I open the finished .GIF. Is it possible Gimp has trouble applying the delay to a high amount of frames? Im used alot of layers, 280 to be exact. The images/layers are from a video I previously converted to PNGs. Any thoughts or advice would be greatly appreciated. Adrian Brisland.
Richard Gitschlag
2012-02-01 18:24:23 UTC (about 13 years ago)
.GIF timing issue
I have occasionally had problems renaming layers -- I type the new name in but the changes do not "stick" when I switch focus away. This could be related behavior given that GIMP manages a GIF's timing and frame disposal as part of each layer name.
From: adrianbrisland@hotmail.com To: gimp-user-list@gnome.org
Date: Tue, 31 Jan 2012 21:49:06 -0700 Subject: [Gimp-user] .GIF timing issue
To gimp-user list recipients, I've run into a problem where I cant edit the delay between frames for my .GIF file. Im looking to set it it 41ms for each frame, which Ive done when prompted as I save my file, but the playback speed seems to stay at 100ms delay when I open the finished .GIF. Is it possible Gimp has trouble applying the delay to a high amount of frames? Im used alot of layers, 280 to be exact. The images/layers are from a video I previously converted to PNGs. Any thoughts or advice would be greatly appreciated. Adrian Brisland.
gimp-user-list mailing list
