Problem with the Newsprint filter?
Problem with the Newsprint filter? Zweibaby 09 Jan 14:20
  Problem with the Newsprint filter? Zweibaby 09 Jan 15:00
   Problem with the Newsprint filter? Jay Smith 09 Jan 15:20
    Problem with the Newsprint filter? peter kostov 09 Jan 16:21
   Problem with the Newsprint filter? Matt Giwer 17 Jan 12:48
2012-01-09 14:20:04 UTC (almost 14 years ago)
So, yesterday I was trying to halftone an image. Everything was working fine, but I couldn't figure out how to use it the way I wanted to. So I found a tutorial. I read it, figured out what I was doing wrong, went on my way. Everything seemed fine.
Then I went to use my newfound knowledge, and lo and behold, the Newsprint filter stopped working. No matter what I tried, the preview image looked just like the original. And when I tried applying the filter anyway, figuring maybe something was just up with the preview panel, nothing happened. The filter pauses to load when I change something, acting like it's working, but nothing happens. The closest thing I've been able to get was the image completely disappearing when I change a certain setting (switch to luminosity, in case you were wondering). I tried googling my problem, but all that gets me is tutorials and the how-to-use guide. I was hoping someone here would know what's wrong and how to fix it.
Thanks in advance!
2012-01-09 15:00:02 UTC (almost 14 years ago)
Then I went to use my newfound knowledge, and lo and behold, the Newsprint filter stopped working. No matter what I tried, the preview image looked just like the original. And when I tried applying the filter anyway, figuring maybe something was just up with the preview panel, nothing happened. The filter pauses to load when I change something, acting like it's working, but nothing happens. The closest thing I've been able to get was the image completely disappearing when I change a certain setting (switch to intensity, in case you were wondering). I tried googling my problem, but all that gets me is tutorials and the how-to-use guide. I was hoping someone here would know what's wrong and how to fix it.
Thanks in advance!
Well, I got it to sort-of work now. It's not exactly how I want it, and I still haven't figured out how it suddenly switched the way it wanted to work, but I pieced something together. I'd still like to know why it did what it did, though.
Jay Smith
2012-01-09 15:20:50 UTC (almost 14 years ago)
Thanks in advance!
Is it possible that your image has multiple layers and that (unknowingly) you were trying to use the filter on a layer for which the filter would have no effect?
Jay
peter kostov
2012-01-09 16:21:28 UTC (almost 14 years ago)
Thanks in advance!
Or any chance that your image is in Grayscale mode? The filter will still work, but the effect will be not as if the image is RGB.
Greetings, Peter
Matt Giwer
2012-01-17 12:48:30 UTC (over 13 years ago)
So, yesterday I was trying to halftone an image. Everything was working fine, but I couldn't figure out how to use it the way I wanted to. So I found a tutorial. I read it, figured out what I was doing wrong, went on my way. Everything seemed fine. Then I went to use my newfound knowledge, and lo and behold, the Newsprint filter stopped working. No matter what I tried, the preview image looked just like the original. And when I tried applying the filter anyway, figuring maybe something was just up with the preview panel, nothing happened. The filter pauses to load when I change something, acting like it's working, but nothing happens. The closest thing I've been able to get was the image completely disappearing when I change a certain setting (switch to intensity, in case you were wondering). I tried googling my problem, but all that gets me is tutorials and the how-to-use guide. I was hoping someone here would know what's wrong and how to fix it. Thanks in advance!
In Photoshop it is called despeckle. Without looking I assume Gimp has it as it has been around in Photoshop for at least 20 years.
