It's possible to duplicate and move a guide (guide line) with Gimp 2.7 ?
Stephane Klein
2012-01-05 21:35:18 UTC (over 13 years ago)
I wonder if in Gimp I can duplicate and move (shift forward) a guide (guide line) ?
Example, I put a horizontal guide on my view. Now I would like to append another horizontal guide 30px below the previous guide.
I didn't found this feature in Gimp 2.7.4
Thanks for your help.
Regards, Stephane
St
2012-01-05 22:03:28 UTC (over 13 years ago)
Hey Stephanie
In cases like this I often find myself making a rectangular selection that shares one side with the existing guide line, and using the tool options dialog for the selection tool to make the selection as many pixels wide or tall as needed. Then I just drag a new guide in and match it to the edge of the selection. If you are used to zooming and panning with the keyboard and mouse wheel, pinpoint accuracy is no problem.
If you don't mind a few extra guides appearing, you can also do "Image > Guides > New Guide From Selection" to place new guide lines on the edges of your adjusted rectangular selection. "Image > Guides > New Guide" may also be even more useful, as it allows you to specify in pixels where the new guide will land on the canvas.
:o)
Steve
Kevin Brubeck Unhammer
2012-01-06 07:28:44 UTC (over 13 years ago)
Stephane Klein writes:
Regards, Stephane
You may find this useful:
http://libregraphicsworld.org/blog/entry/advanced-ways-to-create-guides-in-gimp
best regards, Kevin Brubeck Unhammer
Stephane Klein
2012-01-06 08:12:31 UTC (over 13 years ago)
Le 05/01/2012 22:35, Stephane Klein a
