Gimp Lzw Compression Problem
Gimp Lzw Compression Problem Winter_m 29 Dec 08:10
  Gimp Lzw Compression Problem Winter_m 27 Jan 15:57
   Gimp Lzw Compression Problem Steve Kinney 27 Jan 20:34
   Gimp Lzw Compression Problem Liam R E Quin 28 Jan 02:26
2011-12-29 08:10:05 UTC (over 13 years ago)
Hi everyboady,
I have a problem with the LZW compression of Gimp. I can't view LZW compressed TIFF files with my IDM Desktop 4.0.3. But if I compress the LZW Tiff with Photoshop it works. I've noticed that some propertys are missing in the Gimp compressed file. For this I have made some relatively screenshots.
Hier noch die Links zu den Screenshots;
http://imageshack.us/photo/my-images/42/photoshop3c.png/ http://imageshack.us/photo/my-images/844/photoshop2j.png/ http://imageshack.us/photo/my-images/828/photoshop1k.png/ http://imageshack.us/photo/my-images/845/gimp3n.png/ http://imageshack.us/photo/my-images/80/gimp2.png/ http://imageshack.us/photo/my-images/220/gimp1.png/
2012-01-27 15:57:42 UTC (about 13 years ago)
Hi everyboady,
Thank for your Service so I see how your support works 29 days without any answer is verry low
2012-01-27 20:34:01 UTC (about 13 years ago)
On 01/27/2012 10:57 AM, Winter_m wrote:
Hi everyboady,
I'm afraid this is a user forum, not a commercial help desk. If anyone here had access to an instance of IBM FileNet Image Services or FileNet Image Manager to try and replicate the problem, we might have been able to help. Unfortunately the problem you have encountered is a question of how - or whether - closed source proprietary software displays image files.
I would suggest contacting IBM product support. They are being paid to assure that you have timely and effective access to the data files you need.
:o)
Steve
Liam R E Quin
2012-01-28 02:26:19 UTC (about 13 years ago)
On Fri, 2012-01-27 at 16:57 +0100, Winter_m wrote:
Hi everyboady,
Most likely explanation - you are using PackBits compression and not LZW with PhotoShop. THis is a guess because it's almost certainly nothing at all to do with the XMP metadata you posted.
Most likely you'd need to make two sample TIFF images for people to compare. Include ***DETAILED*** descriptions of how you saved the mage in each case. Example of minimum erquired detail for you to have any hope of getting help from volunteers on this :-) is as follows: (1) in GIMP, used file->save as
(2) entered "gimp.tif" and made no other changes (3) chose "LZW compression"
Liam
