Vignetting correction
Vignetting correction giuliogiuseppecarlo@interfree.it 24 Dec 13:48
  Vignetting correction phanisvara das 24 Dec 14:30
   Vignetting correction Steve Kinney 24 Dec 15:37
    Vignetting correction phanisvara das 24 Dec 16:29
     Vignetting correction Steve Kinney 24 Dec 16:45
2011-12-24 13:48:05 UTC (over 13 years ago)
Hello everyone,
i have a problem trying to remove/adding vignetting with Gimp 2.6.8 and .11.
I have seen there is a nice tool in Filters-Distorts-Lens distorsion.
But if i move only the brighten slider, nothing happens. It works only if i move also the main slider (and in most images, for example portraits, i won't need to touch it).
Is it the intended behaviour or i'm missing something (for example another tool that only removes vignetting and shows a preview)?
Thank you in advance.
------------------------------------------------------------------------------- Valore legale alle tue mail
InterfreePEC - la tua Posta Elettronica Certificata http://pec.interfree.it
phanisvara das
2011-12-24 14:30:10 UTC (over 13 years ago)
On Sat, 24 Dec 2011 19:18:05 +0530, wrote:
Hello everyone,
not sure what type of vignette you're talking about, but to apply one as i used to wile enlarging & developing prints the old way (optically & chemically), i just select an ellipse from upper left to lower right corner, invert the selection, and feather it according to image size. this allows me to either lighten or darken the corner areas, subtly focusing attention on the middle region.
if that's the type of vignette you're looking for, i don't think any tool can do that better than the plain ellipse selection tool.
2011-12-24 15:37:22 UTC (over 13 years ago)
Hello everyone,
Hey y'all,
I usually make a new transparent layer, scale it to about 120% of canvas size, make an elliptical selection with a high value set in "feather edges", invert the selection and and fill it with black. Then I adjust the transparency of the layer until I get the effect I want - which amounts to a realtime preview of the vignette effect, with unlimited do-overs. If the boundary of the dark area is too sharp, use a high value gaussian blur on the vignetting layer.
I make the vignetting layer larger than the canvas because blur effects tend to get a little "bent" at the edge of the layer.
There's always more than one way to do things. For more precise control: Make a duplicate of the main image layer, add a white mask, select the area to be emphasized with a feathered elliptical selection tool, and fill it with black on the mask. Then you can tweak image component of the masked layer to emphasize the "foreground" i.e. the visible part of the original layer - reduce brightness and contrast, blur it a little to simulate a flatter depth of field on the subject, etc. If you deliberately "go a little too far" with your tweaking on this layer, you can dial back its opacity to adjust the amount of distortion in the finished image.
:o)
Steve
phanisvara das
2011-12-24 16:29:14 UTC (over 13 years ago)
Hello everyone,
Hey y'all,
thanks, that's useful. i've never thought much about this vignetting stuff. just was something we did routinely with larger prints, because the lenses tended to loose light toward the edges.
the way you describe it, it can be used as a creative tool, not just subtle final polishing.
2011-12-24 16:45:55 UTC (over 13 years ago)
Yup, in some photos where the composition is weak and the eye is not naturally drawn to the subject, vignetting can save the image. Other times, a photo that naturally looks like it has already had the effect applied, can be made to "pop out and say WOW" by pushing that effect a tiny bit further.
Other times you have to break out the clone and smudge tools and start removing distracting objects... a last resort in most cases. Rarely as I use it, thank God and the developers for the perspective clone tool. And thank Robert A. Heinlein for teaching me that the objective is not a "perfectly accurate" image, but rather, to "fool the eye."
:o)
