separate+ plugin : how to preserve transparency ?
separate+ plugin : how to preserve transparency ? tcharlss 05 Dec 18:20
  separate+ plugin : how to preserve transparency ? Alexandre Prokoudine 05 Dec 18:39
   separate+ plugin : how to preserve transparency ? tcharlss 05 Dec 18:49
    separate+ plugin : how to preserve transparency ? Alexandre Prokoudine 05 Dec 18:59
    separate+ plugin : how to preserve transparency ? Cédric Gémy 05 Dec 19:57
     separate+ plugin : how to preserve transparency ? tcharlss 06 Dec 13:00
2011-12-05 18:20:51 UTC (over 13 years ago)
I installed the separate+ plugin, which works fine. However, when I convert an image to CMYK then export it to TIFF format, the transparency is not preserved. I also tried the cmyktool (from black five imaging), but same problem. Any idea how to do this ?
Thanks in advance
2011-12-05 18:39:28 UTC (over 13 years ago)
I don't think separate+ can do both CMYK and alpha channel. But you can try to do color separation with ImageMagick which does supoport that. Except that it's a comman-line user interface application called 'convert' :)
2011-12-05 18:49:55 UTC (over 13 years ago)
Thanks, I will try ImageMagick ASAP. While I'm on the subject, do you happen to know which image file format is the best for CMYK + transparency, and compatible with scribus 1.4+ ?
2011-12-05 18:59:46 UTC (over 13 years ago)
Sadly, PSD :)
Cédric Gémy
2011-12-05 19:57:04 UTC (over 13 years ago)
IMO
you should just import RGB images (PNG for example). Scribus will auomatically do the job when exporting for print jobs.
2011-12-06 13:00:47 UTC (over 13 years ago)
IMO
Really ? That would be great.
Let's check scribus's documentation !
