Help! - snow animation
Help! - snow animation Jude 27 Nov 18:36
  Help! - snow animation Olivier 27 Nov 18:47
   Help! - snow animation Jude 28 Nov 11:19
  Help! - snow animation David Joyner 27 Nov 18:48
   Help! - snow animation Jude 28 Nov 11:28
2011-11-27 18:36:07 UTC (over 13 years ago)
Can anyone please point me to a step-by-step tutorial to create falling snow?(animation).I'm a complete novice, but can create basic animations and use layers to some degree. I'm using GIMP 2.6. I want to create falling snow on a small picture I've already created. I've spent hours scouring the net today, checking Youtube, but I can't find a clear and concise tutorial. Many thanks for any help. Jude
Olivier
2011-11-27 18:47:36 UTC (over 13 years ago)
2011/11/27 Jude
Basically it's very simple. Add a new transparent layer to your image.
Fill it with RGB Noise. Invert this layer, otherwise the snow is black.
Then, several times, duplicate this layer and offset it down by a few pixels. For a smooth animation, have 30 layers, and change a little the amount of offset down, adding even a small horizontal offset.
Finally, duplicate the background layer as many times as you have snow layers, and merge the duplicate backgrounds each with a snow layer.
Your animation is finished!
Olivier Lecarme
David Joyner
2011-11-27 18:48:11 UTC (over 13 years ago)
On Sun, Nov 27, 2011 at 1:36 PM, Jude wrote:
Can anyone please point me to a step-by-step tutorial to create falling snow?(animation). I'm a complete novice, but can create basic animations and use layers to some degree.
Here is a basic sequence that I would try: 1. start with a blank canvas and add lots of noise (black and white) 2. Blow up the resolution, so it looks very grainy 3. Add linear motion blur
4. invert the colors and then change black to an alpha channel 5. use translations of this to create an animation.
If this works, please post a tutorial somewhere!
Jude
Jude (via gimpusers.com)
gimp-user-list@gnome.org
2011-11-28 11:19:44 UTC (over 13 years ago)
2011/11/27 Jude
Olivier Lecarme
2011-11-28 11:28:57 UTC (over 13 years ago)
Jude
Thanks David!
Having asked this question I eventually found a great tutorial by 'fencepost' on gimpdome, using GIMP-GAP. It worked, but the 'snowfall' was a bit fine for my pic. I wanted big fat flakes rather than a blizzard! I'm working on that. Thanks for your help. The tutorial I used included a lot of what you suggested! It's here: http://www.gimpdome.com/animation-tutorials/animated-snowfall-in-gimp-gap/ Jude
