right-side palate is missing
right-side palate is missing David Wootson 20 Nov 00:13
  right-side palate is missing Alexandre Prokoudine 20 Nov 01:22
  right-side palate is missing devvv 20 Nov 02:20
right-side palate is missing David Wootson 21 Nov 20:55
David Wootson
2011-11-20 00:13:21 UTC (over 13 years ago)
I recently installed Gimp and discovered that the right-side palate is missing. I had previously installed Gimp and
everything was there. I've tried uninstalling and re-installing it a couple times but the palate is still missing. Does
anyone know how to correct this pleblem?
2011-11-20 01:22:04 UTC (over 13 years ago)
2011-11-20 02:20:53 UTC (over 13 years ago)
I think what he means is the layers dialoge etc... You can call it easily by pressing CTRL+L on your keyboard or by make it visible via the menu "Windows" / "Recently closed docks" or "Dockable dialogs"
David Wootson
2011-11-21 20:55:34 UTC (over 13 years ago)
Thank you. It worked :)
