GIMP 2.6.10 unstable installer for 32 and 64-bit systems
GIMP 2.6.10 unstable installer for 32 and 64-bit systems Paul Saumane 02 Nov 20:17
GIMP 2.6.10 unstable installer for 32 and 64-bit systems Paul Saumane 04 Nov 17:59
Paul Saumane
2011-11-02 20:17:59 UTC (over 13 years ago)
Just for information, I just re-installed this release. Formerly, it did not work and I re-installed the 2.6.9 64-bits release. When starting the Gimp, I got the following alert window (translation from French) :
"The procedure entry point gdk_win32_begin_direct_draw_libgtk_only cannot be found in the dynamic links library libgdk_win32_2.0-0.dll"
clicking on OK, the Gimp starts properly and works properly (I did not chech everything). The new display (as far as 64 bits release is concerned) is fantastic.
I am coming from 2.6.9 64-bits release with earlier installations under 32-bits.
I am using Windows 7 ultimate 64-bits. I have two operating systems in the machine XP-32 et 7-64 with two independant HDD's and a third dedicated to data.
Thanks again for this fine work
Best Regards
Paul Saumane
Paul Saumane
2011-11-04 17:59:22 UTC (over 13 years ago)
Good evening,
Addding to the here-under mail :
2.6.10 - 64 bits :
The same alert window appears when saving the work : after clearing the alert, the saving process runs properly.
"Just for information, I just re-installed this release. Formerly, it did not work and I re-installed the 2.6.9 64-bits release. When starting the Gimp, I got the following alert window (translation from French) :
I am using Windows 7 ultimate 64-bits. I have two operating systems in the machine XP-32 et 7-64 with two independant HDD's and a third dedicated to data."
Regards
P.S.
