Light Field Camera
13 of 13 messages available
Light Field Camera Johan Vromans 29 Oct 15:01
  R: Light Field Camera Stefano Rovetta 29 Oct 17:12
   R: Light Field Camera Frank Gore 29 Oct 17:35
    R: Light Field Camera Johan Vromans 29 Oct 17:47
     R: Light Field Camera Frank Gore 29 Oct 17:51
    R: Light Field Camera john Culleton 29 Oct 20:03
     R: Light Field Camera Shlomi Fish 30 Oct 07:15
  Light Field Camera Mikael Ståldal 13 Nov 10:42
   Light Field Camera Burnie West 13 Nov 20:19
Light Field Camera Johan Vromans 29 Oct 17:19
Light Field Camera Frank Gore 29 Oct 17:54
  Light Field Camera Burnie West 29 Oct 23:15
   Light Field Camera Burnie West 12 Nov 21:57
Johan Vromans
2011-10-29 15:01:23 UTC (over 13 years ago)
Light Field Camera
Any ideas how this will impact foto-editing?
www.lytro.com
-- Johan
Stefano Rovetta
2011-10-29 17:12:24 UTC (over 13 years ago)
foto-editing?
www.lytro.com
It could impact much more than editing. E.g., autofocus would become useless.
However they still have to convince me that their idea has roots in reality and in physic laws, and specifying their imaging sensor in terms of a precise number of "light rays" captured, as they do, does not help in this respect.
--Stefano
Johan Vromans
2011-10-29 17:19:21 UTC (over 13 years ago)
Light Field Camera
Noel Stoutenburg writes:
... the camera capturing
"all the light from the scene", when in fact, the camera is only capturing the light from the scene that enters the camera, just like a more conventional digital camera. In the end there will still be an image that can be manipulated,
If I have understood it correctly, the camera does not merely capture the pixels (colour value) but alse the direction where the light came from. This would add a dimension (in the fysical sense) to the information. Think of it as photo-editing becoming 3-dimensional.
-- Johan
Frank Gore
2011-10-29 17:35:06 UTC (over 13 years ago)
They've already announced that initial resulting pictures would be "about HD quality" (ie 1920x1080 or so) from the 11 "megarays" sensor. So editing these images in Gimp should be no problem whatsoever.
It's worth pointing out that consumer-level digital cameras started off with way less resolution than that. New tech needs time to develop. The concept is promising, but if the big companies want nothing to do with it, then it'll just disappear.
Please note, this has absolutely nothing to do with using Gimp. I've tried to add some Gimp relevance in my first paragraph, but it's a stretch. There are far better discussion forums available for these types of subjects.
Frank Gore
www.ProjectPontiac.com
foto-editing?
www.lytro.com
--Stefano _______________________________________________ gimp-user-list mailing list
gimp-user-list@gnome.org
Johan Vromans
2011-10-29 17:47:42 UTC (over 13 years ago)
Frank Gore writes:
As I tried to explain in my other posting, as I understand it image manipulation effectively becomes multi-dimensional.
An image from the LFE can be processed into a ordinary 2-dimensional image, Gimp can handle those.
But what would be required to process the 'raw' (multi-dimensional) data from an LFE camera? Each pixel or group of pixels gets a Z-component that makes the object that this group represents in focus in a particular plane only.
One of the things that would become possible is to create a carefully crafted DOF in an (existing) image.
-- Johan
Frank Gore
2011-10-29 17:51:48 UTC (over 13 years ago)
It currently requires custom proprietary software from the manufacturer, no other software can decode those images yet. As for the mechanics of how it could be done and how to add support for it, that would be best discussed on the dev mailing list. However, since there are currently no publicly available output files from those cameras, the point is moot.
-- Frank Gore
THE place to talk photography!
www.FriendlyPhotoZone.com
Frank Gore
2011-10-29 17:54:02 UTC (over 13 years ago)
Light Field Camera
-- Frank Gore
john Culleton
2011-10-29 20:03:52 UTC (over 13 years ago)
A minor point, but when a message is addressed to both the list and to an individual it helps the rest of us if the list is the addressee and the individual is the cc. That way we can sort messages into folders based on the "To" field.
My incoming messages are sorted into 50 folders, for mailing lists, individual customers and the like.
Burnie West
2011-10-29 23:15:10 UTC (over 13 years ago)
Light Field Camera
-- Frank Gore
It appears (from the underlying thesis) that an array of individual images with different
focuses are captured. The thesis itself indicates 30 images located in a square array,
with the target image captured in each element. Since the images are distributed across
the entire photosensitive array, a fair amount of chromatic dispersion can be detected.
For any image, therefore, 30 times as many pixels (more or less, depending on the subsequent manufacturing details) must be captured. The underlying software has an apparently complex but straightforward sorting problem, allowing to choose whichever pixel is at the best focus for the selected image point in the composite.
It appears at first glance that the images in the light field camera picture gallery have
at least four focal planes available (https://www.lytro.com/living-pictures/282).
From the image editing standpoint (if this is the case), it would not be sharply different
from the refocusing opportunity by providing four successive shots with different focal
length. Of course, the chromatic aberration correction would not be available this way,
nor would moving image capture be handled.
So the thirty images would necessarily have to be divided into the appropriate planes,
presumably using radial symmetry for the chromatic correction.
Seems to me the light field camera is a pretty good idea, and as it evolves over time I
suspect it will be quite interesting.
The thesis itself is available from the lytro.com website - lytro.com/renng-thesis.pdf
-- Burnie
Shlomi Fish
2011-10-30 07:15:22 UTC (over 13 years ago)
Hell John,
That's a non-reliable way to sort messages from mailing lists (as your message indicates). A better way would be to filter based on the headers of List-Id: / List-Post: / etc. which mailing list managers add. Many mailers such as KMail, Claws-Mail and GMail.com support filtering based on that.
Shlomi Fish
Burnie West
2011-11-12 21:57:35 UTC (over 13 years ago)
Light Field Camera
-- Frank Gore
-- Burnie _______________________________________________ gimp-user-list mailing list
An article in the December Atlantic magazine ("Deep Focus" by Rob Walker) suggests that the released Lytro cameras are more complex than the aforementioned thesis describes. According to Rob, Ren Ng's Lytro camera has "integrated hundreds of microlenses into a single device." Certainly interesting; hardly a simple direction for GIMP to pursue.
-- Burnie
Mikael Ståldal
2011-11-13 10:42:46 UTC (over 13 years ago)
Light Field Camera
On 2011-10-29 17:01, Johan Vromans wrote: > Any ideas how this will impact foto-editing?
From GIMP's perspective, I think this can be seen as a new, more advanced, form av RAW images.
Current RAW images allows you to adjust certain aspectes after the exposure, such as white balance. This Light Field Camera adds another aspect to the list of adjustable aspectes: focus.
Currently GIMP has no direct support for any RAW images, you have to pre-process them with a plugin which generates a regular bitmap which is then fed into GIMP. Images from a Ligth Field Camera could be handled in the same way.
Burnie West
2011-11-13 20:19:19 UTC (over 13 years ago)
Light Field Camera
On 11/13/2011 02:42 AM, Mikael St
