Documentation - Behind/Color Erase modes
Documentation - Behind/Color Erase modes Richard Gitschlag 08 Sep 17:03
Richard Gitschlag
2011-09-08 17:03:44 UTC (almost 14 years ago)
I do a lot of traditional drawing, so one of the common tasks I perform in GIMP is cleaning up the background after scanning a character I've sketched on paper (erasing stray pencil flecks and so on). I've frequently used the Erase (with alpha channel) to perform this task, because it means I end up with a transparency that I can paint some manner of digital backsplash underneath.
My general process for doing this was: 1 - Duplicate the layer
2 - Perform a full Color to Alpha transformation on the lower layer (white as background) 3 - Use the Eraser on the upper layer, with a soft-edged brush, to clean up the background. Any mistakes during the process I can clean up using the Alt (anti-erase) modifier.
This yields a smoother foreground-background fade around the edges than simply the Eraser on a single layer. But recently I discovered the faster way of doing this task: The "Color erase" painting mode, which performs a Color-to-Alpha transition as part of any other drawing operation. So I don't need to worry about managing multiple layers anymore. However I do need a function to perform the inverse, so I can compensate for mistakes...
...and it dawns on me that the "Behind" paint mode is exactly what I'm looking for here. All I need to do now is set up a keyboard shortcut to toggle between the two modes and I'll be good to go.
Anyway, it should be noted in GIMP's online manual (http://docs.gimp.org/2.6/en/gimp-tools-paint.html#gimp-paint-mode-examples ) that the "Behind" and "Color Erase" blending modes are inverse functions of each other, with "color erase" transforming solid color to alpha and "behind" transforming alpha to solid color. (Should I file this on the bugtracker?)
