Rough metallic surface
Rough metallic surface "Mikael St 31 Jul 09:29
  Rough metallic surface rich 01 Aug 08:35
"Mikael St
2011-07-31 09:29:54 UTC (almost 14 years ago)
I wanted to make a rough metallic surface and I ended up with this by fiddling around with a back-to-white gradient and emboss it. I finally got a clean 200x200 image that alings seamlessy and can be used as a pattern:
http://www.staldal.nu/gimp/patterns/metallic.pat
(You can make it golden by colorify with yellow.)
Are there any other strateiges for making a rough metallic surface?
(Feel free to use this pattern if you like it.)
rich
2011-08-01 08:35:27 UTC (almost 14 years ago)
You might use a bump map. Open a suitable image, plenty if you search google images, in your case perhaps part of a larger image as a base. Then in your new image it is filters -> map -> bumpmap and point at the 'rusted' image.
You get an effect like this. http://i.imgur.com/73HYK.jpg
Since you are aiming at a small image for a tilable pattern, then its filters -> map -> make tilable.
