Noise reduction
7 of 7 messages available
Noise reduction "Mikael St 21 Jul 21:51
  Noise reduction Frank Gore 21 Jul 22:02
  Noise reduction JPL 21 Jul 22:14
   Noise reduction Patrick Horgan 22 Jul 18:50
    Noise reduction Frank Gore 22 Jul 19:32
Noise reduction Jernej Simončič 21 Jul 22:45
Noise reduction Kevin Brubeck Unhammer 25 Jul 10:32
"Mikael St
2011-07-21 21:51:20 UTC (almost 14 years ago)
Noise reduction
Is there any better noise reduction filter for GIMP than the built in Wavelet Denoise? It does remove the noise, but also make the image a bit blurry.
Wavelet Denoise in ufraw has the same problem.
I know it is possible to do it better since my new camera, Canon PowerShot S95, does it better when saving to JPEG. But the camera doesn't do noise reduction when saving to RAW.
Frank Gore
2011-07-21 22:02:40 UTC (almost 14 years ago)
Noise reduction
Try the GMIC plugin. There are 2 methods in that plugin that do a great job of noise reduction, but the options are so vast and complex, it's tough to know where to start. There are a couple of tutorials online that show you how to use GMIC specifically for noise reduction. Unfortunately I've misplaced those links.
-- Frank Gore
www.ProjectPontiac.com
JPL
2011-07-21 22:14:09 UTC (almost 14 years ago)
Noise reduction
There are several denoising scripts here : registry.gimp.org/ I like Unsharp Mask 2 0.12 which gives me very fine results (I use only the first five settings).
Gimp-user mailing list
Jernej Simončič
2011-07-21 22:45:36 UTC (almost 14 years ago)
Noise reduction
Try Selective Gaussian Blur - it often gives very good results (just lower the threshold).
Patrick Horgan
2011-07-22 18:50:58 UTC (almost 14 years ago)
Noise reduction
In your camera it's able to do a black shot to get the average noise of your sensors. That gives it a HUGE advantage. It can just subtract that from the image. Some of the sensor wells are always more noisy than others. You can do the same if you know a bit about graphics, take a few shots with your lens cap on in raw mode, get them on to your computer, make a noise mask with averaged values from each pixel, then subtract that from all your raw images. Surely there's someone's software that can do that already given the black images. Anyone?
Patrick
Frank Gore
2011-07-22 19:32:06 UTC (almost 14 years ago)
Noise reduction
Black frame noise reduction only applies to long exposures for removing hot pixels. It does nothing beneficial to reduce high-ISO noise.
Frank Gore
2011-07-25 10:32:18 UTC (almost 14 years ago)
Noise reduction
Frank Gore writes:
I believe the most important G’MIC filters are:
- Anisotropic smoothing - Patch-based smoothing
both under the "Enhancement" menu. See
https://jcornuz.wordpress.com/2009/02/07/gmic-next-gen-greycstoration/ http://www.gimpforphotos.com/tutorials-beginner/noise-reduction-with-gmic.html
for some more information.
