Suggestions for GIMP layout
10 of 10 messages available
Suggestions for GIMP layout Harald Pfeiffer 15 Jul 19:30
  Suggestions for GIMP layout Chris Mohler 15 Jul 19:48
   Suggestions for GIMP layout Stefan Maerz 16 Jul 06:04
    Suggestions for GIMP layout Alexandre Prokoudine 16 Jul 06:27
     Suggestions for GIMP layout saluk 30 Jul 19:22
      Suggestions for GIMP layout John Culleton 30 Jul 20:33
       Suggestions for GIMP layout Ofnuts 31 Jul 08:33
        Suggestions for GIMP layout John Culleton 01 Aug 02:07
         Suggestions for GIMP layout Michael Schumacher 01 Aug 11:59
      Suggestions for GIMP layout Roseroberta Pauling 31 Jul 18:22
Harald Pfeiffer
2011-07-15 19:30:09 UTC (almost 14 years ago)
I'm a new mailing list user so feel free to point out my errors so I can get it right next time.
I joined the GIMP User mailing list because I was unable to find an easier way to send feedback of any kind.... and the developer list didn't seem appropriate because I'm not a developer and wouldn't be. I simply have some comments and suggestions that I want to pass on in the hope that the development group makes some changes to GIMP in the future.
First, to be clear, I'm referring to the most recent version of GIMP which appears not to have been updated in a long while... v2.6.11
I've *HAD* GIMP for quite some time and occasionally use it but each time I do I find it a bit too disorganized for my liking so I return to the software I usually use. But recently, I upgraded to Windows 7 (64) and found that my preferred software would not install in the 64-bit environment. So I had to try something else so there I was looking at GIMP again.
One of my first complaints came when I took a screen shot then pasted the contents of the clipboard into GIMP and tried to save the file. My plan was to save it as a Windows Bitmap (*.BMP) so naturally I selected SAVE AS... and then arrived at the troublesome SAVE AS window.
1) I noted that the folder tree was not in sync with the SAVE IN folder. Not even when I created a new folder did the tree realign itself to show the location where that folder had been created. That made it VERY easy to end up creating folders in completely unexpected locations. And of course, finding a misplaced folder is equally difficult. So my first recommendation is that GIMP's SAVE IMAGE window be restructured to cause the folder tree under the PLACES heading, to always remain in sync with the active folder .... to expand to reveal it. So whether you change the SAVE IN folder drop list, or you click one of the folder shortcut buttons, or you create a new folder..... however a folder is accessed, the tree should always expand to that folder.
2) When I first tried to save my image as a BMP, I tried to do so by changing the drop list at the bottom right of the SAVE IMAGE window. It begins with ALL IMAGES as the default so it seemed to me that selecting Windows Bitmap (*.BMP) in that list would do the trick.... which of course it did not. Strangely the file was given an XCF extension. It was only after I expanded the item entitled LIST FILE TYPE (BY EXTENSION) that my choice of the "Windows Bitmap (BMP)" file type took on any meaning. The point here is that it wasn't intuitive. I had to save twice and first got something I didn't expect then corrected my mistake to achieve the saving of a BMP as expected. I'm still not clear about why the right hand filter exists if it serves no purpose when saving? So my second suggestion is to clarify the file type selection for saving files so that it becomes intuitive and unmistakable.
3) The third issue is one of esthetics. GIMP is divided into separate windows. We all see the Toolbox, an Image Window and a Layers window.... but they are separate windows rather than child processes. That leads to an interesting problem when you want to minimize (not close) GIMP. Closing GIMP shuts down all the open windows but minimizing has effect on only the central image window. In fact, the Toolbox and Layer windows don't even have minimize buttons. So there is no way to actually completely minimize GIMP. There will always be some remnant of it left covering the screen unless the Toolbox etc... windows are closed. This was really awkward for me as my graphics work has me constantly minimizing and restoring. But maximizing presents a similar problem. Since the Toolbox and Layer windows are not child windows, they obstruct the central image window when it is maximized and that can get annoying really fast. In my *efforts* to use GIMP I found myself constantly resizing and closing and opening different elements of the program and that was not only time consuming and required additional effort but also left me wanting a different image editing program. So my third suggestion is to consolidate GIMPs Toolbox, Layer and similar windows into GIMPs main window so that they are child processes and never obstruct the image window. That would also allow for minimizing everything at once.
GIMP seems like a very capable image editing program so I'd really like to see it continue in development. And if it does, I hope to see these suggestions somehow incorporated into it.
Now I just have to cross my fingers and hope that the right people see this post and feel the same way.
I'm outta here.
HAP
Chris Mohler
2011-07-15 19:48:35 UTC (almost 14 years ago)
From someone who's been following the development of GIMP a bit:
On Fri, Jul 15, 2011 at 2:30 PM, Harald Pfeiffer wrote:
1) [...]So my first recommendation is that GIMP's SAVE IMAGE     window be restructured to cause the folder tree under the PLACES     heading, to always remain in sync with the active folder
I don't see any "tree" (then again I just looked over the dialog in XP, not win7). The items under "Places" are just bookmarks for convenience that can be added/removed. GIMP uses GTK's file Open and Save dialogs, which differ a bit from native windows dialogs. It may just be that you'll need to spend some time getting used to the differences.
2) [...]    So my second suggestion is to clarify the file type selection for     saving files so that it becomes intuitive and unmistakable.
The upcoming version will divide "Save" from "Export" - where saving will produce XCF files (native GIMP files) and exporting will produce formats like BMP, PNG, etc. In 2.6 I leave the 'By Extension' area minimized and just put the desired extension in the filename. So if I was working on 'image.xcf' and wanted to save as BMP I would do 'Save As' and type'image.bmp' in the filename box, and it will produce a BMP file.
Single-Window Mode is coming in the next version (as an option). In the meantime, use the key to show/hide the dialogs and toolbox.
HTH, Chris
Stefan Maerz
2011-07-16 06:04:27 UTC (almost 14 years ago)
On this topic, I have a question. With this new "Save" and "Export" feature, will it be possible to save an .xcf and export the image all at once? As in I press save, and two files are generated (or overwritten).
The boss is rather indecisive frequently, and I have to go back and manually edit a bunch of diagrams.
-Stefan Maerz
Gimp-user mailing list
2011-07-16 06:27:38 UTC (almost 14 years ago)
You will have to script it, at least for now :)
2011-07-30 19:22:55 UTC (over 13 years ago)
This workflow is troubling. I don't work with xcf, but with real image formats (png, jpg). The old way had its problems (always asking what settings to use for export), but this isn't any better. I now have no way to see if I have exported my image or not, because the change indicator is not updated when the image is exported. Also, if you are going to display a warning message when I try to save as jpg, you might as well handle the exporting there as before. Leave the new export workflow as is, but its restrictive to only use xcf as the "native" image type, when depending on what I'm working on I may want a different "native" type, while yet exporting to something else.
Back to 2.6 for me :(
John Culleton
2011-07-30 20:33:42 UTC (over 13 years ago)
"Export"
image all
what
no way
indicator is
display
handle the
its
depending on
I have a different problem. I am processing a series of screen shots through Gimp to desaturate them (color pages cost more then B/W pages.) Each time I retrieve a screen shot from: /usr/local/active/scribusp
and desaturate it I must chase down the entire file tree to save it again in
/usr/local/active/scribusp.
I think Gimp should remember the directory from which an image was loaded.
Gimp 2.6.11 on Linux.
2011-07-31 08:33:43 UTC (over 13 years ago)
This is the way it works... Maybe Gimp gets shy because /usr and /usr/local aren't writable by non-root users?
Roseroberta Pauling
2011-07-31 18:22:40 UTC (over 13 years ago)
can someone please help me......I want to stop getting all these messages.  I just wanted one question answered about gimp.  There was no way through there manual and I ended up figuring it out myself.  I wanted to sign in as I liked to the forum and just get my question answered instead I am ending up with email after email, and my login is still not working correctly because I was ending up like a dog chasing there tail from one point to another.....can someone help or get this to some who supervises that forum.  Thanks
________________________________
To: gimp-user@lists.XCF.Berkeley.EDU Cc: team@gimpusers.com
Sent: Saturday, July 30, 2011 2:22 PM Subject: [Gimp-user] Suggestions for GIMP layout
-- saluk (via gimpusers.com)
John Culleton
2011-08-01 02:07:44 UTC (over 13 years ago)
shots
it
again in
was
loaded.
On my machine /usr/local/ is writable by my own user name. In fact my own user name owns /usr/local and all its subordinates. So rights are not the problem. I just have to go through more clicks than is reasonable just to get back to where I started.
2011-08-01 11:59:48 UTC (over 13 years ago)
Von: John Culleton
So the default path of the export dialog as described in the Save & Export specification for 2.8 should fulfill your needs:
http://gui.gimp.org/index.php/Save_%2B_export_specification#exporting_files
Regards, Michael
