UFRaw default settings
UFRaw default settings "Mikael St 15 Jul 11:32
  UFRaw default settings Alexandre Prokoudine 15 Jul 11:39
   UFRaw default settings "Ville P 15 Jul 12:00
    UFRaw default settings "Mikael St 15 Jul 18:07
     UFRaw default settings Alexandre Prokoudine 15 Jul 18:13
      UFRaw default settings John Culleton 18 Jul 15:58
"Mikael St
2011-07-15 11:32:08 UTC (almost 14 years ago)
I'm using the UFRaw plugin to GIMP for importing RAW images. However, if I do any adjustments for a particular image, UFRaw will save that as default when I import the image to GIMP.
This is quite annoying, is there a way to turn it off?
2011-07-15 11:39:07 UTC (almost 14 years ago)
Check the tab with saving/exporting options. It used to have a setting exactly for that.
Gimp-user mailing list
"Ville P
2011-07-15 12:00:29 UTC (almost 14 years ago)
I haven't used UFRaw in a while, but I remember that that option and some others were available only if you start UFRaw as a standalone application, not as a GIMP plug-in. So as a workaround you can run UFRaw separately and save the photos as PNGs to open in GIMP.
Luckily Darktable exists now so one doesn't have to bother with UFRaw on Linux anymore.
"Mikael St
2011-07-15 18:07:49 UTC (almost 14 years ago)
On 2011-07-15 14:00, Ville Pätsi wrote: >> Check the tab with saving/exporting options. It used to have a >> setting exactly for that.
> I haven't used UFRaw in a while, but I remember that that option and > some others were available only if you start UFRaw as a standalone > application, not as a GIMP plug-in. So as a workaround you can run > UFRaw separately and save the photos as PNGs to open in GIMP.
Yes, now I found it. Actually, once it is set there, it works as I want it in the GIMP plugin as well. Nice.
> Luckily Darktable exists now so one doesn't have to bother with UFRaw > on Linux anymore.
What advantages does Darktable offer over GIMP with UFRaw plugin?
2011-07-15 18:13:49 UTC (almost 14 years ago)
On Fri, Jul 15, 2011 at 10:07 PM, Mikael Ståldal wrote:
 > Luckily Darktable exists now so one doesn't have to bother with UFRaw  > on Linux anymore.
32bit per color channel precision LAB as main processing color space
Threaded processing, OpenCL support
Non-destructive editing
Nice color adjustment and artistic tools.
John Culleton
2011-07-18 15:58:40 UTC (almost 14 years ago)
bother with UFRaw
on Linux anymore.
UFRaw plugin?
user
I am a total novice with using RAW format. But no guts no glory. I had taken two shots in RAF (Fuji RAW) format of a color wheel. When I import them into Darktable they come up greenish.
What do I do next? Do I need a special profile for the Fuji camera?
John Culleton
"Death Wore Black" Police procedural:
http://www.deathworeblack.com/
"Create Book Covers with Scribus"
http://booklocker.com/books/4055.html
